Univention-actualise auf 2.2.0.3 schlägt fehl (?)
german
#1
Ich versuche gerade ein update auf 2.2.0.3 durchzuführen:
root@pdc:~# univention-security-update local --file /tmp/ucs-security-2.2-0.3-i386.tgz
Update to Security Update 2.2-sec3
root@pdc:~# univention-actualise
Running apt-get update
Setting pkgdb/scan
File: /etc/apt/apt.conf.d/60invoke
Upgrading system
E: failed to upgrade <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Setting pkgdb/scan
Setting pkgdb/scan
Reading package lists... Done
Building dependency tree... Done
root@pdc:~#
Was mich irritiert ist die Meldung “E: failed to upgrade” (mit Pfeil markiert).
Im Log sieht eigentlich alles gut(?) aus:
root@pdc:~# cat /var/log/univention/actualise.log
Ign file: 2.2-1/all/ Release.gpg
Ign file: 2.2-1/i386/ Release.gpg
Ign file: 2.2-1/extern/ Release.gpg
Ign http://pdc.hbs-ag.local 2.2-0/all/ Release.gpg
Ign http://pdc.hbs-ag.local 2.2-0/extern/ Release.gpg
Ign http://pdc.hbs-ag.local 2.2-0/i386/ Release.gpg
Ign http://pdc.hbs-ag.local 2.2-1/all/ Release.gpg
Ign http://pdc.hbs-ag.local 2.2-1/extern/ Release.gpg
Ign http://pdc.hbs-ag.local 2.2-1/i386/ Release.gpg
Ign http://pdc.hbs-ag.local sec1/all/ Release.gpg
Ign http://pdc.hbs-ag.local sec1/extern/ Release.gpg
Ign http://pdc.hbs-ag.local sec1/i386/ Release.gpg
Ign http://pdc.hbs-ag.local sec2/all/ Release.gpg
Ign http://pdc.hbs-ag.local sec2/i386/ Release.gpg
Ign http://pdc.hbs-ag.local sec3/all/ Release.gpg
Ign http://pdc.hbs-ag.local sec3/extern/ Release.gpg
Ign http://pdc.hbs-ag.local sec3/i386/ Release.gpg
Ign http://pdc.hbs-ag.local hotfixes/all/ Release.gpg
Ign http://pdc.hbs-ag.local hotfixes/extern/ Release.gpg
Ign http://pdc.hbs-ag.local hotfixes/i386/ Release.gpg
Ign file: 2.2-1/all/ Packages
Ign file: 2.2-1/i386/ Packages
Ign file: 2.2-1/extern/ Packages
Ign http://pdc.hbs-ag.local 2.2-0/all/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local 2.2-0/extern/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local 2.2-0/i386/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local 2.2-1/all/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local 2.2-1/extern/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local 2.2-1/i386/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local sec1/all/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local sec1/extern/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local sec1/i386/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local sec2/all/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local sec2/i386/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local sec3/all/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local sec3/extern/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local sec3/i386/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local hotfixes/all/ Packages/DiffIndex
Ign http://pdc.hbs-ag.local hotfixes/extern/ Packages
Ign http://pdc.hbs-ag.local hotfixes/i386/ Packages/DiffIndex
Get:1 http://pdc.hbs-ag.local hotfixes/extern/ Packages [867B]
Hit http://pdc.hbs-ag.local 2.2-0/all/ Packages
Hit http://pdc.hbs-ag.local 2.2-0/extern/ Packages
Hit http://pdc.hbs-ag.local 2.2-0/i386/ Packages
Hit http://pdc.hbs-ag.local 2.2-1/all/ Packages
Hit http://pdc.hbs-ag.local 2.2-1/extern/ Packages
Hit http://pdc.hbs-ag.local 2.2-1/i386/ Packages
Hit http://pdc.hbs-ag.local sec1/all/ Packages
Hit http://pdc.hbs-ag.local sec1/extern/ Packages
Hit http://pdc.hbs-ag.local sec1/i386/ Packages
Hit http://pdc.hbs-ag.local sec2/all/ Packages
Hit http://pdc.hbs-ag.local sec2/i386/ Packages
Hit http://pdc.hbs-ag.local sec3/all/ Packages
Hit http://pdc.hbs-ag.local sec3/extern/ Packages
Hit http://pdc.hbs-ag.local sec3/i386/ Packages
Hit http://pdc.hbs-ag.local hotfixes/all/ Packages
Hit http://pdc.hbs-ag.local hotfixes/i386/ Packages
Fetched 867B in 0s (2417B/s)
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
***** Starting univention-actualise at Fri Sep 18 11:05:36 2009
root@pdc:~#
Im Webclient ist unter “About” zu finden:
Hat das jetzt funktioniert oder nicht?
Gruß
Martin
#2
anscheinend gibt univention-actualise diese Meldung aus, wenn nichts zu installieren ist. Dazu habe ich einen Eintrag in unserem Bug-Tracking-System erstellt.
Ihr System ist bereits auf Version 2.2-1-3 und muss deshalb keine Pakete aus dem Security-Update installieren.
Dies können Sie mit folgendem Befehl überprüfen:
ucr search ^version
Mit freundlichen Grüssen
Tobias Scherer
Einspielen von Hotfix funktioniert nicht?
#3
Super. Besten Dank für die Info.
