After renewing the certificates Thunderbird refuses to talk to dovecot with encryption. Other clients do not seem to have a problem. So I need to temporarily enable unencrypted IMAP access. Which UCR registry value must be changed in order to let dovecot talk plain imap ? I cannot locate the original mail/dovecot/ssl/disable_plaintext_auth in the registry.
I have the same problem after renew the root certificate. To enable plain communication without SSL I change the config file of dovecot on the server. /etc/dovecot/conf.d/10-ssl.conf
ssl = no
and added
disable_plaintext_auth = no
Restart dovecot
Then changed the server setting on the thunderbird client to do not use ssl
