root@ucs-debian-client-01:/home/user# kpasswd sylvain
sylvain@ITSFOSS.INTRANET's Password:
New password for sylvain@ITSFOSS.INTRANET:
Verify password - New password for sylvain@ITSFOSS.INTRANET:
Success : Password changed
In addition, I created the home directory for the user with the right permissions:
total 8
4 drwxr-xr-x 2 2008 5001 4096 Apr 7 10:07 sylvain
4 drwxr-xr-x 15 user user 4096 Mar 28 17:34 user
lib-pam heimdal is installed.
BUT I’m still unable to log in my system using the “sylvain” user.
I don’t know if this is related, but you can see above my system does not seem to map uid 2008 / gid 5001 to the proper names.
This is confirmed by getpwname being unable to locate the domain user:
to be honest, my last Debian integration was: following the guide for Ubuntu and copying that one missing package (auth-client-config) from the Ubuntu repos, then installing it via “dpkg -i”. I guess that’s a dirty hack, but it works flawlessly so far
I just looked into your archive. I think the parts with PAM is missing at all. So there will be no mapping/lookup from PAM to ldap.
I’m not sure that this will fix it at all, but in the Ubuntu integration guide there are some additional configurations to be done (or done by the SSSD installation) in the PAM stack.
I think you have to configure some parts in /etc/pam.d/common-auth. As I’m using an Ubuntu Client, I can’t check it out for you, but my /etc/pam.d/common-auth look like this:
# /etc/pam.d/common-auth - authentication settings common to all services
# This file is included from other service-specific PAM config files,
# and should contain a list of the authentication modules that define
# the central authentication scheme for use on the system
# (e.g., /etc/shadow, LDAP, Kerberos, etc.). The default is to use the
# traditional Unix authentication mechanisms.
# As of pam 1.0.1-6, this file is managed by pam-auth-update by default.
# To take advantage of this, it is recommended that you configure any
# local modules either before or after the default block, and use
# pam-auth-update to manage selection of other modules. See
# pam-auth-update(8) for details.
# here are the per-package modules (the "Primary" block)
auth required pam_group.so use_first_pass
auth [success=3 default=ignore] pam_unix.so nullok_secure try_first_pass
auth [success=2 default=ignore] pam_winbind.so krb5_auth krb5_ccache_type=FILE cached_login try_first_pass
auth [success=1 default=ignore] pam_sss.so use_first_pass
# here's the fallback if no module succeeds
auth requisite pam_deny.so
# prime the stack with a positive return value if there isn't one already;
# this avoids us returning an error just because nothing sets a success code
# since the modules above will each just jump around
auth required pam_permit.so
# and here are more per-package modules (the "Additional" block)
auth optional pam_cap.so
# end of pam-auth-update config
The line auth [success=1 default=ignore] pam_sss.so use_first_pass is responsible for the lookup in SSSD (and ldap as well).
Maybe libpam-ccreds will work for you.
No, it isn’t (i.e.: “sylvain” is not in /etc/passwd)
That was part of the puzzle. Depending the parameters given, “getent” do not issue the same system call. And in some case, I get back the domain user. In the other one, I didn’t.
According to “man getent”:
Apparently, with my current settings, “{set,get,end}pwent” and “getpwnam” do not provide consistent results.
For your other remarks, I’ll check that in few minutes when I will have access to my test environment.
I’ve installed the nss-updatedb package and run those commands:
The domain users are successfully retrieved and I can see the entry for the user “sylvain” in the /var/lib/misc/passwd.db file.
But “getent passwd sylvain” still do not successfully retrieve the user data.
I didn’t installed before libpam-sss. It is now done. And my /etc/pam.d/common-auth was updated to something similar to yours as part of the process (with the exception of pam_winbind and krb5_ccache_type which are absent in mine)
Indeed there was an issue with my /etc/nsswitch.conf file. The {passwd,group} entries were missing the db option
# /etc/nsswitch.conf
# Example configuration of GNU Name Service Switch functionality.
# If you have the `glibc-doc-reference' and `info' packages installed, try:
# `info libc "Name Service Switch"' for information about this file.
passwd: compat ldap [NOTFOUND=return] db
group: compat ldap [NOTFOUND=return] db
shadow: compat ldap [NOTFOUND=return] db
gshadow: files
hosts: files mdns4_minimal [NOTFOUND=return] dns
networks: files
protocols: db files
services: db files sss
ethers: db files
rpc: db files
netgroup: nis sss
sudoers: files sss
Hi sieroux,
based on the provided information for joining ubuntu-clients into an UCS domain, i could successfully join my Debian testsystem into such a domain.
Here is how i did it.
I installed a clean UCS 4.2 server without selecting any components.
UCS Domain Name: example.com
IP: 192.168.22.100
The client system (Debian 8.7.1) was also installed without any additional Software. DNS was set to the IP of the UCS server and domain set equal to the UCS Domain Name.
Login as root to the client system and execute the following script:
As a matter of fact, I finally fixed my Debian test system, but as I tried many different things, I wasn’t sure exactly what was my main issue
What I can say is it was apparently related to sssd I didn’t install initially. My test system being a minimal Debian install, it was pretty possible some required packages were missing.
All that being said, after a quick check, the solution you mentioned seems to work on a stock Debian system.
Interesting enough, when comparing your script with the one provided on https://docs.software-univention.de/domain-4.1.html#ext-dom-ubuntu, I noticed you skip the part related to auth-client (which is available on Ubuntu, but not on genuine Debian). Was that on purpose?
Hi sieroux,
with the package auth-client-config you can store multiple authentication profiles. More detailed informations are explained here. As far as i understand it, this is useful for logins to different domains on the same computer. Correct me if i am wrong.
So far it is not mandatory if you have only one domain.
You can try to adapt the steps 1.3 (Configuring user logins) and 1.4 (Kerberos integration).
I haven’t tried that with Debian, only with CentOS. Let me know if it works.
