UMC mail module missing
I installed OX for evaluation then uninstalled it and removed that test server from the domain.
I now am missing the UMC mail module for setting up imap domains. I still have the OX Mail and OX resources UMC modules on the DC.
I tried removing the following packages from Extended software management on the DC:
univention-ox-common
univention-ox-diectory-integration
univention-ox-framework
If I go into the OX Mail UMC module, I see context10 OX context, but I can’t remove it. (“The deletion of the OX context object is not allowed!”)
Is there something else I can do to remove the remnants of the OX?
many thanks, Julian
I did the removal once, basically by deleting everything from the LDAP with relation to the OX-integration. Some attributes had to be deleted with low-level methods like ldapmodify.
There are definitions of UDM Modules and UMC settings in cn=univention but I dont know for sure, what happens if one tries to delete them and would not not try to do so if I am not sure that a recovery of the while system is possible,
Best Regards,
Dirk Ahrnke
