I have strange problem with an UCS 4.3 connected to an MS AD.
If I change the IP of this UCS, I cannot login to the UMC anymore. After I enter the login credentials, the site reloads to the page where I can enter my login credentials, It’s an endless loop.
When I switch back to the old IP via the console, everything works fine, again.
I tried solving the problem with forcing to execute all joining scripts, but this didn’t help
The univention-console-web-server.log shows these entries:
29.04.18 14:54:57.628 MAIN ( PROCESS ) : SessionClient(0x7efc38799190): _authenticated: success=True status=200 message=None
29.04.18 14:54:57.628 MAIN ( PROCESS ) : auth_type=None
29.04.18 14:55:16.117 MAIN ( PROCESS ) : SessionClient(0x7efc38799ad0): _authenticated: success=True status=200 message=None
29.04.18 14:55:16.118 MAIN ( PROCESS ) : auth_type=None
29.04.18 14:56:12.976 MAIN ( PROCESS ) : SessionClient(0x7efc3872c250): _authenticated: success=True status=200 message=None
29.04.18 14:56:12.977 MAIN ( PROCESS ) : auth_type=None
29.04.18 14:59:36.858 MAIN ( PROCESS ) : SessionClient(0x7efc3873c290): _authenticated: success=True status=200 message=None
29.04.18 14:59:36.858 MAIN ( PROCESS ) : auth_type=None
29.04.18 15:07:26.479 MAIN ( PROCESS ) : SessionClient(0x7efc3873cf90): _authenticated: success=True status=200 message=None
29.04.18 15:07:26.480 MAIN ( PROCESS ) : auth_type=None
The univention-console-server.log shows these entries:
29.04.18 14:54:57.470 MODULE ( PROCESS ) : Setting auth type to None
29.04.18 14:54:57.627 MAIN ( PROCESS ) : Updating user password in 0 running module processes (auth-type: None).
29.04.18 14:55:16.001 MODULE ( PROCESS ) : Setting auth type to None
29.04.18 14:55:16.018 ACL ( WARN ) : Error reading credentials from LDAP: Traceback (most recent call last):
File "/usr/lib/pymodules/python2.7/univention/management/console/acl.py", line 368, in _read_from_ldap
userdn = self.lo.searchDn(filter_format('(&(objectClass=person)(uid=%s))', [self.username]), unique=True)[0]
IndexError: list index out of range
29.04.18 14:55:16.116 MAIN ( PROCESS ) : Updating user password in 0 running module processes (auth-type: None).
29.04.18 14:55:16.222 MAIN ( PROCESS ) : Connection timed out.
29.04.18 14:55:20.283 MAIN ( PROCESS ) : Connection timed out.
29.04.18 14:55:27.364 MAIN ( PROCESS ) : Connection timed out.
29.04.18 14:55:27.364 MAIN ( PROCESS ) : Processor: dying
29.04.18 14:55:27.782 MAIN ( PROCESS ) : Connection timed out.
29.04.18 14:55:28.225 MAIN ( PROCESS ) : Connection timed out.
29.04.18 14:55:31.683 MAIN ( PROCESS ) : Connection timed out.
29.04.18 14:55:45.889 MAIN ( PROCESS ) : Connection timed out.
29.04.18 14:55:45.889 MAIN ( PROCESS ) : Processor: dying
29.04.18 14:55:46.371 MAIN ( PROCESS ) : Connection timed out.
29.04.18 14:55:47.086 MAIN ( PROCESS ) : Connection timed out.
29.04.18 14:55:51.172 MAIN ( PROCESS ) : Connection timed out.
29.04.18 14:56:12.791 MODULE ( PROCESS ) : Setting auth type to None
29.04.18 14:56:12.975 MAIN ( PROCESS ) : Updating user password in 0 running module processes (auth-type: None).
29.04.18 14:56:42.677 MAIN ( PROCESS ) : Connection timed out.
29.04.18 14:56:42.677 MAIN ( PROCESS ) : Processor: dying
29.04.18 14:56:43.133 MAIN ( PROCESS ) : Connection timed out.
29.04.18 14:56:43.808 MAIN ( PROCESS ) : Connection timed out.
29.04.18 14:56:47.488 MAIN ( PROCESS ) : Connection timed out.
29.04.18 14:59:36.726 MODULE ( PROCESS ) : Setting auth type to None
29.04.18 14:59:36.856 MAIN ( PROCESS ) : Updating user password in 0 running module processes (auth-type: None).
29.04.18 15:00:01.616 MAIN ( PROCESS ) : Connection timed out.
29.04.18 15:00:06.608 MAIN ( PROCESS ) : Connection timed out.
29.04.18 15:00:06.608 MAIN ( PROCESS ) : Processor: dying
29.04.18 15:00:07.001 MAIN ( PROCESS ) : Connection timed out.
29.04.18 15:00:07.910 MAIN ( PROCESS ) : Connection timed out.
29.04.18 15:00:11.324 MAIN ( PROCESS ) : Connection timed out.
29.04.18 15:07:26.219 AUTH ( WARN ) : Canonicalization of username was not possible: Invalid credentials
29.04.18 15:07:26.309 MODULE ( PROCESS ) : Setting auth type to None
29.04.18 15:07:26.478 MAIN ( PROCESS ) : Updating user password in 0 running module processes (auth-type: None).
29.04.18 15:07:56.197 MAIN ( PROCESS ) : Connection timed out.
29.04.18 15:07:56.197 MAIN ( PROCESS ) : Processor: dying
29.04.18 15:07:56.735 MAIN ( PROCESS ) : Connection timed out.
29.04.18 15:07:57.411 MAIN ( PROCESS ) : Connection timed out.
29.04.18 15:08:00.874 MAIN ( PROCESS ) : Connection timed out.
Querying the LDAP via console was fine.
I’m a little bit confused, because this is the first time, I saw an UCS with this problem after changing the IP, but I must say, this was the first 4.3 UCS with IP change, also.
Thanks in advanced for every hint on solving this problem.
Christian.
