UMC limit standard container to specific ou
Hi all,
having several OUs, I wonder if there’s a way to limit the UMC dialog to a specific OU when creating e.g. a User object. AFAIK, the OU can be in the path for standard user containers: userPath: 1.
In my scenario, you see then all the OUs with userPath attribute set to 1.
Cheers
Sebastian
solved it by myself. I already implemented an LDAP ACL, that limited the access. … simply forgot, to ucr commit /etc/ldap/slapd.conf the changes :shushing_face:
