UDM Goup modify
Hi, I have to add a group inside other group.
I’ve write:
univention-directory-manager groups/group modify --dn cn='father,ou=xxxx,dc=xxxx,dc=xxxx' --append groups='cn=son,ou=xxxx,dc=xxxx,dc=xxxx'
but “WARNING: No attribute with name groups in this module, value not appended.”
What is right sintax?
Thank you
Regards
The attributes name is nestedGroup.
If I don’t know the name, I configure it graphically using the UMC, and then look on the command line.
Greetings
Daniel
Thank you, --append nestedGroup= works fine
