UCS to Cisco WLC EAP-TLS
Hi Im trying to configure Cisco WLC using UCS for authentication with EAP-TLS. I havent found any topics regarding this setup with UCS, It exist a lot using Windows server as NPS/RADIUS and CA server. does anyone have a working config between UCS and WLC?
Thanks,
just as a hint: UCS supports Radius, too.
So please check UCS docs regarding Radius and you should easily be done.
/KNEBB
