same here !!!
This is a GLPI issue & the filters needed, best place to ask is the GLPI forums.
There is not even any simple debugging in the GLPI, it just fails… (yep… ok it has a test button, but no feedback)
The most annoying thing is that i use “apache directory studio” with the same settings & it works fine.
so maybe try that first , till you get a working config with the directory studio, & try and tx the settings to GLPI
you might “try” setting :
The Defaultserver to “yes”
The port to “636”
The “used Binds” to “NO”!! to go for the most basic auth first
then on the left tabs go down to " advanced information",
which really is a misnomer it should be “advanced configuration”
set the TLS to “NO”
