UCS Slave as Failover Emailserver
Can UCS slave server be a failover Email server? I’ve successfully joined the slave server to the master but when I looked on the slave server it says that the email server is already installed on its master, i tried accessing the IMAP port of the slave but it has failed. Should I install the email service on the slave or am i doing something wrong?
Thank You.
