I tried to register a custom schema manually like this:
ucs_registerLDAPExtension “$@”
–schema /path/to/appschemaextension.schema
but the command does not exist.
That’s a function of a built-in shell-library, see Univention Developer Reference .
You need to source the shell-lib first:
# UCS 5.0:
. /usr/share/univention-lib/join.sh
ucs_registerLDAPExtension [...]
# UCS 4.4:
. /usr/share/univention-lib/base.sh
somehow this doesn’t work. I tried using:
source /usr/share/univention-lib/join.sh
ucs_registerLDAPExtension --schema /root/my.schema
when I register this:
. /usr/share/univention-lib/ldap.sh
it gives me an error:
ERROR: ucs_registerLDAPExtension: Unable to determine Debian package name
ERROR: This function only works in joinscript or postinst context
it works like this:
ucs_registerLDAPExtension --packagename "mySchema" --packageversion "1" --schema /root/my.schema
maybe join.sh is not needed
