UCS re-installation (factory reset?)
is there any way to do a factory reset without reinstalling from scratch, i.e. to get back to a clean slate like when you have the installation when first installing UCS with all config and data cleared? Reason for this is to check what to do when, say, evaluation is over (i.e. using test data/apps/domain/etc …).
I suppose a clean re-install is the best option but just wanted to check.
I don’t think so
but you’ll have the option to install on hypervisor (ESXi, Virualbox, KVM etc) and there you may take snapshot after basic install and revert to that snapshot after testing
rg
Christian
thanks, that’s what I ended up doing.
