Hey there!
iam trying to get the ucs-sso office 365 site through a reverse proxy that our employees can reach it outside our company network. We have a reverse proxy server and that is running nginx. thats the config i try to run:
upstream example {
server example.ktest.local:443;
server {
listen 80;
server_name example.ktest.de;
return 301 https://$host$request_uri;
server {
listen 443 ssl http2;
server_name xx;
access_log /var/log/nginx/example.access.log;
error_log /var/log/nginx/example.error.log;
ssl_certificate /etc/letsencrypt/live/sso.k-test.de/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/sso.k-test.de/privkey.pem;
ssl_protocols TLSv1.2 TLSv1.1 TLSv1;
ssl_ciphers EECDH+AESGCM:EDH+AESGCM:EECDH:EDH:!MD5:!RC4:!LOW:!MEDIUM:!CAMELLIA:!ECDSA:!DES:!DSS:!3DES:!NULL;
ssl_prefer_server_ciphers on;
ssl_dhparam /etc/nginx/ssl/dhparam2048.pem;
ssl_ecdh_curve secp384r1;
ssl_session_cache shared:SSL:30m;
ssl_session_timeout 10m;
ssl_session_tickets on;
ssl_session_ticket_key /etc/nginx/ssl/nginx_ticketkey;
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains; preload";
location / {
proxy_pass https://example.ktest.local;
proxy_next_upstream error timeout invalid_header http_500 http_502 http_503 http_504;
proxy_set_header Accept-Encoding "";
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
add_header Front-End-Https on;
proxy_redirect off;
what do i need to change? Cause iam getting a 502 Error. Do i need to edit the apache config at the ucs itself?
