UCS Master mit Slave in DMZ: Join schlägt fehl
Mahlzeit,
UCS Master mit 4.1-1 errata152 installiert, läuft sauber. Tut genau das, was er soll.
In der DMZ den Slave installiert mit 4.1-0 errata149
Hinweis: “Version 4.1 is available but cannot be installed. Component ‘jenkins_20160303’ is not yet available for newer release versions.”
Firewallports richtung Master sind geöffnet: 22,37,389,7389,6669,636
Dann sollte ja der Slave auch mal joinen (in der UCM übrigens das gleiche Ergebnis):
/usr/sbin/univention-join
Ergebnis:
— snip —
univention-join: joins a computer to an ucs domain
copyright © 2001-2016 Univention GmbH, Germany
Enter DC Master Account : Administrator
Enter DC Master Password:
Search DC Master: done
Check DC Master: done
Stop LDAP Server: done
Search ldap/base done
Start LDAP Server: done
Search LDAP binddn done
Sync time: done
Join Computer Account: done
Stopping univention-directory-listener daemon: done
Sync ldap-backup.secret: done
Check TLS connection: done
Download host certificate: done
Restart LDAP Server: done
Sync Kerberos settings: done
Not updating kerberos/adminserver
Configure 01univention-ldap-server-init.inst done
Configure 03univention-directory-listener.inst done
  • Join failed! *
  • Contact your system administrator *
  • Message: FAILED: failed.ldif exists.
— snap —
Die Tipps mit dem"failed.ldif" aus sdb.univention.de/content/14/292 … found.html
bin ich durch.
Also join.log anschauen:
— snip —
return func(self,*args,**kwargs)
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 215, in simple_bind_s
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 476, in result3
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 483, in result4
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 106, in _ldap_call
result = func(*args,**kwargs)
ldap.INVALID_CREDENTIALS: {‘desc’: ‘Invalid credentials’}
21.04.16 08:36:56.164 LISTENER ( WARN ) : handler: quota (failed)
UNIVENTION_DEBUG_BEGIN : uldap.__open host=corny.foobar.de port=7389 base=dc=foobar,dc=de
UNIVENTION_DEBUG_END : uldap.__open host=corny.foobar.de port=7389 base=dc=foobar,dc=de
File “/usr/lib/univention-directory-listener/system/quota.py”, line 213, in handler
if _is_container_change_relevant(new, old):
File “/usr/lib/univention-directory-listener/system/quota.py”, line 139, in _is_container_change_relevant
lo = _get_ldap_connection()
File “/usr/lib/univention-directory-listener/system/quota.py”, line 116, in _get_ldap_connection
connection = univention.uldap.getMachineConnection(ldap_master=False)
File “/usr/lib/pymodules/python2.7/univention/uldap.py”, line 106, in getMachineConnection
lo=access(host=ucr[‘ldap/server/name’], port=port, base=ucr[‘ldap/base’], binddn=ucr[‘ldap/hostdn’], bindpw=bindpw, start_tls=start_tls, decode_ignorelist=decode_ignorelist, reconnect=reconnect)
File “/usr/lib/pymodules/python2.7/univention/uldap.py”, line 177, in init
self.__open(ca_certfile)
File “/usr/lib/pymodules/python2.7/univention/uldap.py”, line 219, in __open
self.lo.simple_bind_s(self.binddn, self.__encode_pwd(self.bindpw))
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 879, in simple_bind_s
res = self._apply_method_s(SimpleLDAPObject.simple_bind_s,*args,**kwargs)
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 860, in _apply_method_s
— snap —
Falsche Credentials. Aber WO? Der Rest hat ja gefunzt.
Gerne einen Tipp.
André
jenkins in der UCR disabled.
[code]ERROR: A LDAP connection to the configured LDAP servers with the machine
account has failed (invalid credentials)!
This MUST be fixed before the update can continue.
   This problem can be corrected by setting the content of the file
   /etc/machine.secret to the password of the computer object using
   Univention Management Console.
[/code]
also /etc/machine.secret auf dem Slave. Von welchem/wessen Account ist, das und welches Hashverfahren wird verwendet?
Oder ist es das vom Master, welches der Maschine zugewiesen wir und regelmäßig geändert wird?
Vielen Dank.
André
wie kommt denn der Jenkins auf eine nicht gejointe Maschine? Geht denn das Appcenter inzwischen auch auf Standalone-Server?
/etc/machine.secret ist IMO das Klartextkennwort des Computerkontos. Auch hier wundert mich, dass die Datei bei einer nicht gejointen Maschine existiert.
Ja, das ist das Kennwort, welches regelmäßig über reinen Cronjob geändert wird.
Ich würde zunächst prüfen, ob man gegen den Master unter Verwendung des Adminkontos ein ldapsearch machen kann. Wenn das geht, dasselbe mit dem Computerkonto probieren, Anhaltspunkte, was man machen muß, finden sich in /usr/bin/univention-ldapsearch.
Viele Grüße,
Dirk Ahrnke
Mahlzeit,
also er packt die jenkins Einträge in der UCR immer mit drauf und flagged als ENABLED. Wenn man ihn auf DISABLED setzt läuft das Update. Allerdings NUR wenn man einen nachträglichen Beitritt zur Domäne für den Slave angegebn hat. D.h. beide Maschinen sind jetzt auf gleichem Software Level.
Stelle an der er beim univention-join aussteigt ist die Routine in Zeile 197:
if [ "$server_role" = "domaincontroller_slave" ]; then
                                                if [ -n "$listener_supply_notifier" -a "$listener_supply_notifier" = "yes" ]; then
                                                        univention-scp "$DCPWD" -q \
        "${DCACCOUNT}@${DCNAME}:/var/lib/univention-ldap/notify/transaction" \
        "$USERTMP/tlog" >/dev/null 2>&1
                                                        id="$(</var/lib/univention-directory-listener/notifier_id)"
                                                        awk -F ' ' '{ if ( $1 <= '$id') print }' "$USERTMP/tlog" >/var/lib/univention-ldap/notify/transaction
                                                fi
Auf der Masterseite erscheint dann im /var/log/auth.log:
Apr 22 12:30:01 ldap CRON[12421]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 22 12:30:01 ldap CRON[12424]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 22 12:30:01 ldap CRON[12423]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 22 12:30:01 ldap CRON[12422]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 22 12:30:01 ldap CRON[12425]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 22 12:30:01 ldap CRON[12421]: pam_unix(cron:session): session closed for user root
Apr 22 12:30:01 ldap CRON[12422]: pam_unix(cron:session): session closed for user root
Apr 22 12:30:02 ldap CRON[12424]: pam_unix(cron:session): session closed for user root
Apr 22 12:30:02 ldap CRON[12423]: pam_unix(cron:session): session closed for user root
Apr 22 12:30:05 ldap CRON[12425]: pam_unix(cron:session): session closed for user root
User root ist auf dem Master mit dem public-key hinterlegt.
/etc/machine.secret ist auch auf dem Slave vor dem join nicht vorhanden und wird beim univention-join erstellt.
Muss auf dem Master noch was eingetragen werden, fehlt ein offener Port?
Auf dem Packetfilter läuft offiziell nichts gegen die Wand.
Schönes WE
André
Letzte Möglichkeit: Master neu aufgesetzt. Läuft smooth durch.
André
