UCS Installation on i686 Platform
Hello, is UCS considering offering installation ISOs for i686 platforms, currently have that challenge. If anyone has been able to install the ISO on an i686 platform, kindly share.
Thanks.
Iso Images for i386 are not available for UCS 4 - If you update from UCS 3 to UCS 4 then you would be able to continue to use i386.
Kind regards,
Jens Thorp-Hansen
Thanks Thorp-Hansen
Mastodon
