hello all.
ucs is running. finally. found the error from the last topic. anyway
need some advice how to do following
ucs should replace windows ads, only 3 terminal servers will be used (anybody did that already ? running a terminal server farm connected at ucs domain controller with ads function ? as i read, it should work)
but the bigger question is
IP 60.0
a, UCS DC
b, User: name at mail1 com
c, DNS, LDAP, certs other infra components -
IP 61.0
a, UCS with share
b, User: name @ mail2 com
c, Nextcloud and egroupware
d, truenas, need to mounted in UCS
e, Terminal Server apps -
IP 62.0
a, UCS
b, User: name @ mail3 com
and so on, like 63, 64. every environment is the same.
as mentioned, only in 60 is the domain controller. in the other i only need NC and egroupware, and some other tools and programms.
also i want truenas storage mounded because of Shadow Copy oder versioning. as i understand this feature is not available in ucs.
the self service is cool option but does it have self service for creating users for authenticated users ?
can i run own terminal servers apps there ?
