UCS CUPS Print Server - Hold For Authentication
Greetings,
I hope you are well. Any tips on getting the UCS Print Server working? I’ve added a printer and have sent a print job, but all I get is a “Hold for Authentication” error on my iMac.
Then I tried a “lpadmin -p printer -o auth-info-required=negotiate” command, which made a credential prompt appear but putting in my domain credentials, while correct, just put me back on the “Hold for Authentication” loop. Any suggestions?
Regards,
David.
Got it working. The only way it would work, that I have found anyway, is if I set the printer’s protocol on UCS as LPD and add an IPP printer on my workstation.
Interesting, is there any news here in the meantime?
Why Cups did’nt user Kerberos auth from user login?
