Hi@all,
on our UCS (4.4.7, current patch level) I get the warning in the system diahnosis:
"Check modified UCR template.
Errors were found due to univention-check-templates. The following UCR templates have been modified locally. Updated versions are called DATEINAME.dpkg-*. The files should be checked for differences.
/etc/univention/templates/files/etc/bareos/bareos-sd.d/device/FileStorage.conf"
Nothing has been changed in the file /etc/univention/templates/files/etc/bareos/bareos-sd.d/device/FileStorage.conf and a file with “DATEINAME.dpkg-*” does not exist.
What is the reason for this message?
with best
sven
