UCS 5 Portal not Loading
after Upgrading the Univention Server to 5.0 the Portal isnt working anymore.
It shows the Loading Circle forever.
when I try to get information through the command line with univention-portal-server i get :
I had the Portal Preview installed before Updating and had to remove it in order to get the update working.
Did someone have the same Issue before ?
Felix
I haven’t seen that issue myself, but was the portal server running when you issued the command on the command line? Address already in use would be normal I think if the server was already running.
Have you looked at the log files? I am guessing you already restarted after uninstalling the preview and installing the update.
