I’m trying to upgrade UCS, which fails. Please see the details below:
Current UCS version is: 4.4-8 errata1019
Desired UCS version is: 5.0-0
Following error is located in the update log (/var/log/univention/updater.log):
python_ucr_template_compatibility:
The following UCR templates are not compatible with Python 3:
/etc/univention/templates/files/etc/pam.d/univention-management-console.d/30_tally (package: univention-management-console-server)
See https://help.univention.com/t/17948 for information on how to proceed with each template.
I followed the link, and located this thread:
Unfortunately, 30_tally module is not in the list of the templates that can be safely removed (as indicated in the post from the link above), and is a short Python script (10~15 lines). Any suggestions on how to solve this are much appreciated. Thank you.
