UCS 5.0.1 : Appcenter behaves strangely
Hi@all,
The Appcenter behaves very strangely at times under UCS 5. All systems: Master + Node are newly installed (5.0.1). I wanted to install Rocket.Chat on the Node but the app was not listed.
After I called ‘apt update’ on the console and logged into the UMC again, the app was suddenly available.
The attempt to install Rocket.Chat aborted with an error. Unfortunately, I did not make a note of it.
After restarting the node, Rocket.Chat disappeared again from the Appcenter.
The installation runs in a separate (virtual) network under Proxmox because a UCS 4.4 environment is running in the LAN.
I therefore cannot access the log file directly from the PC (LAN) but only via a test client that is also installed as a VM in this network.
grafik
Unfortunately, the Proxmox console (VNC) does not offer copy & paste :frowning:
with best
sven
Hello @pixel , there is bug which reminds me of your description. Maybe this is the problem. But without more log content it’s hard to tell. Please provide more information.
best regards :slight_smile:
ok, I don’t think it’s the same bug.
apt update, browser reload in Appcenter and Rocket.Chat shows up again.
→ Installation:
grafik
appcenter.log:
grafik
Ok, I used port forwarding to gain access from the LAN via SSH. Here is the entire log
  4942 actions.register                 22-02-03 18:44:11 [   DEBUG]: Calling register
  4942 actions.register.progress        22-02-03 18:44:11 [   DEBUG]: 0
  4942 actions.update                   22-02-03 18:44:11 [   DEBUG]: Calling update
  4942 actions.update.progress          22-02-03 18:44:11 [   DEBUG]: 0
  4942 actions.register                 22-02-03 18:44:11 [   DEBUG]: No apps given. Using all
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No repository to register
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: Creating data directories for fetchmail...
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: Creating data directories for mailserver...
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for adconnector found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for admindiary-backend found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for admindiary-frontend found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for adtakeover found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for benno-mailarchiv found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for bluespice found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for brainyoo found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for collabora found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for collabora-online found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for cups found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for dhcp-server found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for dudle found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for egroupware found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for ethercalc found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for etherpad-lite found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [   DEBUG]: App is not docker. Skip registering host
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for humhub found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for itiseasybusiness found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for jitsimeet found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for letsencrypt found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for m23 found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for nextcloud found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for odoo found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for onlyoffice-ds found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for onlyoffice-ds-integration found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for open-xchange-guard found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for open-xchange-text found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for openid-connect-provider found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for owncloud found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for ox-connector found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for oxseforucs found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for pkgdb found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for privacyidea-saml found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for prometheus-node-exporter found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for radius found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for relution found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for riot found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for rocketchat found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for samba-memberserver found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for samba4 found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for seafile found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for self-service found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for self-service-backend found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for squid found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for synapse found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for ucsschool found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for ucsschool-apis found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for ucsschool-id-connector found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for ucsschool-kelvin-rest-api found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for ucsschool-veyon-proxy found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for univention-demo-data found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for webweaver found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for wekan found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for wordpress found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for xwiki found. Nothing to remove
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: No hostdn for zammad found. Nothing to remove
  4942 actions.update                   22-02-03 18:44:11 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/app-categories.ini"...
  4942 actions.update                   22-02-03 18:44:11 [   DEBUG]:   ... Not Modified
  4942 actions.update                   22-02-03 18:44:11 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/rating.ini"...
  4942 actions.register                 22-02-03 18:44:11 [    INFO]: Removing localhost from LDAP object
  4942 actions.register                 22-02-03 18:44:12 [    INFO]: Registering UCR for fetchmail
  4942 actions.register                 22-02-03 18:44:12 [    INFO]: Marking fetchmail=6.3.26 as installed
  4942 actions.update                   22-02-03 18:44:12 [   DEBUG]:   ... Not Modified
  4942 actions.update                   22-02-03 18:44:12 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/license_types.ini"...
  4942 actions.register                 22-02-03 18:44:12 [    INFO]: Adding localhost to LDAP object
  4942 actions.register                 22-02-03 18:44:12 [    INFO]: Registering UCR for mailserver
  4942 actions.register                 22-02-03 18:44:12 [    INFO]: Marking mailserver=12.0 as installed
  4942 actions.update                   22-02-03 18:44:12 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/ucs.ini"...
  4942 actions.register                 22-02-03 18:44:12 [    INFO]: Removing localhost from LDAP object
  4942 actions.update                   22-02-03 18:44:12 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/suggestions.json"...
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Adding bluespiceActivated to list of attributes
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Removing DN: cn=bluespiceActivated,cn=bluespice,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 actions.register                 22-02-03 18:44:12 [   DEBUG]: Not removing attributes, App is still installed somewhere
  4942 actions.update                   22-02-03 18:44:12 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/5.0/all.tar.gpg"...
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Adding itiseasybusinessActivated to list of attributes
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Removing DN: cn=itiseasybusinessActivated,cn=itiseasybusiness,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Adding jitsimeetActivated to list of attributes
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Removing DN: cn=jitsimeetActivated,cn=jitsimeet,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 actions.update                   22-02-03 18:44:12 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.4/all.tar.gpg"...
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Adding nextcloudUserQuota to list of attributes
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Adding nextcloudUserEnabled to list of attributes
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Adding nextcloudGroupEnabled to list of attributes
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Removing DN: cn=nextcloudUserQuota,cn=nextcloud,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Removing DN: cn=nextcloudUserEnabled,cn=nextcloud,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Removing DN: cn=nextcloudGroupEnabled,cn=nextcloud,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Adding odooActivated to list of attributes
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Removing DN: cn=odooActivated,cn=odoo,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 actions.update                   22-02-03 18:44:12 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.3/all.tar.gpg"...
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Adding relutionActivated to list of attributes
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Removing DN: cn=relutionActivated,cn=relution,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Adding rocketchatActivated to list of attributes
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Removing DN: cn=rocketchatActivated,cn=rocketchat,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Adding seafileActivated to list of attributes
  4942 attributes                       22-02-03 18:44:12 [   DEBUG]: Removing DN: cn=seafileActivated,cn=seafile,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 actions.update.progress          22-02-03 18:44:12 [   DEBUG]: 100
  4942 cache                            22-02-03 18:44:13 [   DEBUG]: Cache outdated. Need to rebuild
  4942 cache                            22-02-03 18:44:13 [   DEBUG]: Unable to get mtime for cache: [Errno 2] Datei oder Verzeichnis nicht gefunden: '/var/cache/univention-appcenter/appcenter.software-univention.de/5.0/.apps.de.json'
  4942 cache                            22-02-03 18:44:13 [   DEBUG]: Cannot load cache: mtimes of cache files do not match: None < 1643895064.079741
  4942 attributes                       22-02-03 18:44:13 [   DEBUG]: Adding synapseActivated to list of attributes
  4942 attributes                       22-02-03 18:44:13 [   DEBUG]: Removing DN: cn=synapseActivated,cn=synapse,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 cache                            22-02-03 18:44:13 [   DEBUG]: Saved 41 apps into cache
  4942 cache                            22-02-03 18:44:13 [   DEBUG]: Unable to get mtime for cache: [Errno 2] Datei oder Verzeichnis nicht gefunden: '/var/cache/univention-appcenter/appcenter.software-univention.de/4.4/.apps.de.json'
  4942 cache                            22-02-03 18:44:13 [   DEBUG]: Cannot load cache: mtimes of cache files do not match: None < 1643895067.879741
  4942 attributes                       22-02-03 18:44:13 [   DEBUG]: Adding webweaverActivated to list of attributes
  4942 attributes                       22-02-03 18:44:13 [   DEBUG]: Removing DN: cn=webweaverActivated,cn=webweaver,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 attributes                       22-02-03 18:44:13 [   DEBUG]: Adding wekanActivated to list of attributes
  4942 attributes                       22-02-03 18:44:13 [   DEBUG]: Removing DN: cn=wekanActivated,cn=wekan,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 cache                            22-02-03 18:44:15 [   DEBUG]: Saved 419 apps into cache
  4942 cache                            22-02-03 18:44:15 [   DEBUG]: Cache outdated. Need to rebuild
  4942 cache                            22-02-03 18:44:15 [   DEBUG]: Unable to get mtime for cache: [Errno 2] Datei oder Verzeichnis nicht gefunden: '/var/cache/univention-appcenter/appcenter.software-univention.de/4.3/.apps.de.json'
  4942 cache                            22-02-03 18:44:15 [   DEBUG]: Cannot load cache: mtimes of cache files do not match: None < 1643895069.859741
  4942 cache                            22-02-03 18:44:16 [   DEBUG]: Saved 255 apps into cache
  4942 actions.register.progress        22-02-03 18:44:16 [   DEBUG]: 100
  4942 utils                            22-02-03 18:47:26 [   DEBUG]: send_information: action=get app=rocketchat value=None status=200
  4942 utils                            22-02-03 18:47:26 [   DEBUG]: tracking information: {'action': 'get', 'status': 200, 'uuid': '57d3bbee-91f8-46ae-a6a5-e15eed967cbc', 'role': 'memberserver', 'app': 'rocketchat', 'version': '3.18.2', 'system-uuid': '5ece7845-1055-4047-9038-f305cb58abd0'}
  4942 utils                            22-02-03 18:47:41 [    INFO]: Resolving dependencies for rocketchat
  4942 actions.install                  22-02-03 18:47:46 [    INFO]: 4.4/rocketchat=3.18.2 is a Docker App. No sane dry run is implemented
  4942 actions.install                  22-02-03 18:47:46 [   DEBUG]: Calling install
  4942 actions.install.progress         22-02-03 18:47:46 [   DEBUG]: 0
  4942 utils                            22-02-03 18:47:46 [    INFO]: Resolving dependencies for rocketchat
  4942 actions.install                  22-02-03 18:47:46 [    INFO]: Going to install Rocket.Chat (3.18.2)
  4942 actions.install                  22-02-03 18:47:46 [    INFO]: Showing License agreement for 4.4/rocketchat=3.18.2
  4942 actions.install                  22-02-03 18:47:46 [    INFO]: Showing README for 4.4/rocketchat=3.18.2
  4942 actions.configure                22-02-03 18:47:46 [   DEBUG]: Calling configure
  4942 actions.configure.progress       22-02-03 18:47:46 [   DEBUG]: 0
  4942 actions.configure                22-02-03 18:47:46 [    INFO]: Configuring 4.4/rocketchat=3.18.2
  4942 actions.configure.progress       22-02-03 18:47:46 [   DEBUG]: 100
  4942 actions.install                  22-02-03 18:47:46 [   DEBUG]: Calling prescript (preinst)
  4942 actions.install                  22-02-03 18:47:46 [   DEBUG]: /var/cache/univention-appcenter/appcenter.software-univention.de/4.4/rocketchat_20211101074333.preinst does not exist
  4942 packages                         22-02-03 18:47:46 [   DEBUG]: Holding LOCK
  4942 actions.install                  22-02-03 18:47:46 [    INFO]: Creating data directories for rocketchat...
  4942 attributes                       22-02-03 18:47:46 [   DEBUG]: Adding rocketchatActivated to list of attributes
  4942 actions.install.progress         22-02-03 18:47:46 [   DEBUG]: 5
  4942 actions.install                  22-02-03 18:47:46 [    INFO]: Registering UCR for rocketchat
  4942 actions.install                  22-02-03 18:47:46 [    INFO]: Marking 4.4/rocketchat=3.18.2 as installed
  4942 actions.install                  22-02-03 18:47:47 [    INFO]: Setting ports for apache proxy
  4942 actions.install                  22-02-03 18:47:48 [    INFO]: Adding localhost to LDAP object
  4942 actions.install                  22-02-03 18:47:48 [    INFO]: Setting overview variables
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Changed: {'rocketchat'}
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Local hosts are: ['com01.gehr.lan', '192.168.83.6']
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Matched 'ucs/web/overview/entries/service/rocketchat/icon' -> '/univention/js/dijit/themes/umc/icons/scalable/apps-rocketchat_20211101074333.svg'
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Matched 'ucs/web/overview/entries/service/rocketchat/port_http' -> '80'
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Matched 'ucs/web/overview/entries/service/rocketchat/port_https' -> '443'
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Matched 'ucs/web/overview/entries/service/rocketchat/label' -> 'Rocket.Chat'
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Matched 'ucs/web/overview/entries/service/rocketchat/label/de' -> 'Rocket.Chat'
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Matched 'ucs/web/overview/entries/service/rocketchat/description' -> 'Open Source Team Communication'
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Matched 'ucs/web/overview/entries/service/rocketchat/description/de' -> 'Open Source Team Communication'
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Matched 'ucs/web/overview/entries/service/rocketchat/link' -> '/rocketchat/'
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Matched 'ucs/web/overview/entries/service/rocketchat/link-target' -> 'newwindow'
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Processing cn=rocketchat,cn=entry,cn=portals,cn=univention,dc=gehr,dc=lan
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Attrs: {'name': 'rocketchat', 'icon': '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', 'displayName': [('en_US', 'Rocket.Chat'), ('de_DE', 'Rocket.Chat')], 'description': [('en_US', 'Open Source Team Communication'), ('de_DE', 'Open Source Team Communication')], 'linkTarget': 'newwindow'}
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Links: [('en_US', 'https://com01.gehr.lan/rocketchat/'), ('en_US', 'http://com01.gehr.lan/rocketchat/'), ('en_US', 'https://192.168.83.6/rocketchat/'), ('en_US', 'http://192.168.83.6/rocketchat/')]
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: DN not found...
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: ... creating
  4942 portalentries                    22-02-03 18:47:48 [   DEBUG]: Adding entry to cn=domain-service,cn=category,cn=portals,cn=univention,dc=gehr,dc=lan
  4942 actions.install                  22-02-03 18:47:48 [   DEBUG]: Calling /etc/init.d/apache2 reload
  4942 actions.install                  22-02-03 18:47:48 [    INFO]: Reloading apache2 configuration (via systemctl): apache2.service.
  4942 actions.install                  22-02-03 18:47:48 [   DEBUG]: /etc/init.d/apache2 returned with 0
  4942 actions.install.progress         22-02-03 18:47:48 [   DEBUG]: 10
  4942 actions.install.progress         22-02-03 18:47:48 [   DEBUG]: 15
  4942 actions.install                  22-02-03 18:47:48 [    INFO]: Registering schema /usr/share/univention-appcenter/apps/rocketchat/rocketchat.schema
  4942 attributes                       22-02-03 18:47:49 [   DEBUG]: Adding rocketchatActivated to list of attributes
  4942 actions.install                  22-02-03 18:47:49 [    INFO]: Registering attribute rocketchatActivated
  4942 attributes                       22-02-03 18:47:49 [   DEBUG]: Creating DN: cn=rocketchatActivated,cn=rocketchat,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 actions.install.progress         22-02-03 18:47:49 [   DEBUG]: 25
  4942 actions.install                  22-02-03 18:47:49 [    INFO]: Registering the container host rocke-04698890 for rocketchat
  4942 actions.install.progress         22-02-03 18:47:50 [   DEBUG]: 30
  4942 docker                           22-02-03 18:47:50 [   DEBUG]: Getting network for 4.4/rocketchat=3.18.2
  4942 docker                           22-02-03 18:47:50 [   DEBUG]: Testing 172.16.0.0/24
  4942 docker                           22-02-03 18:47:50 [   DEBUG]: Refusing due to "main subnet"
  4942 docker                           22-02-03 18:47:50 [   DEBUG]: Testing 172.16.1.0/24
  4942 actions.install                  22-02-03 18:47:50 [    INFO]: Downloading app images
  4942 docker                           22-02-03 18:47:50 [   DEBUG]: Running in /var/lib/univention-appcenter/apps/rocketchat/compose:
  4942 docker                           22-02-03 18:47:50 [    INFO]: Running command: docker-compose -p rocketchat pull
  4942 docker                           22-02-03 18:47:50 [    INFO]: Pulling mongo              ...
  4942 docker                           22-02-03 18:47:50 [    INFO]: Pulling rocketchat         ...
  4942 docker                           22-02-03 18:47:50 [    INFO]: Pulling mongo-init-replica ...
  4942 docker                           22-02-03 18:47:51 [    INFO]: e[1Ae[2K
Pulling mongo-init-replica ... pulling from rocketchat-mongo-ini...
e[1Be[1Ae[2K
Pulling mongo-init-replica ... digest: sha256:36797ccde48d912fa1...
e[1Be[1Ae[2K
Pulling mongo-init-replica ... status: image is up to date for d...
e[1Be[2Ae[2K
Pulling rocketchat         ... pulling from rocketchat-rocketchat
e[2Be[2Ae[2K
Pulling rocketchat         ... digest: sha256:bb1d32a48a1e1eec46...
e[2Be[2Ae[2K
Pulling rocketchat         ... status: image is up to date for d...
e[2Be[1Ae[2K
Pulling mongo-init-replica ... e[32mdonee[0m
e[1Be[2Ae[2K
Pulling rocketchat         ... e[32mdonee[0m
e[2Be[3Ae[2K
Pulling mongo              ... pulling from rocketchat-mongo
e[3Be[3Ae[2K
Pulling mongo              ... digest: sha256:36797ccde48d912fa1...
e[3Be[3Ae[2K
Pulling mongo              ... status: image is up to date for d...
e[3Be[3Ae[2K
Pulling mongo              ... e[32mdonee[0m
e[3B
  4942 actions.install                  22-02-03 18:47:51 [    INFO]: Initializing app image
  4942 docker                           22-02-03 18:47:51 [   DEBUG]: Getting network for 4.4/rocketchat=3.18.2
  4942 docker                           22-02-03 18:47:51 [   DEBUG]: Found 172.16.1.0/24
  4942 utils                            22-02-03 18:47:51 [   DEBUG]: Running in /var/lib/univention-appcenter/apps/rocketchat/compose:
  4942 utils                            22-02-03 18:47:51 [    INFO]: Running command: docker-compose -p rocketchat up -d --no-build --no-recreate
  4942 utils                            22-02-03 18:47:51 [    INFO]: Creating network "rocketchat_appcenter_net" with the default driver
  4942 utils                            22-02-03 18:47:51 [    INFO]: Pool overlaps with other one on this address space
  4942 utils                            22-02-03 18:47:51 [   ERROR]: Command docker-compose -p rocketchat up -d --no-build --no-recreate failed with: Creating network "rocketchat_appcenter_net" with the default driver
Pool overlaps with other one on this address space (1)
  4942 packages                         22-02-03 18:47:51 [   DEBUG]: Releasing LOCK
  4942 actions.install                  22-02-03 18:47:51 [CRITICAL]: Creating network "rocketchat_appcenter_net" with the default driver
  4942 actions.install                  22-02-03 18:47:51 [ WARNING]: Aborting...
  4942 actions.remove                   22-02-03 18:47:51 [   DEBUG]: Calling remove
  4942 actions.remove.progress          22-02-03 18:47:51 [   DEBUG]: 0
  4942 utils                            22-02-03 18:47:51 [    INFO]: Resolving dependencies for rocketchat
  4942 actions.remove                   22-02-03 18:47:51 [    INFO]: Going to remove Rocket.Chat (3.18.2)
  4942 actions.remove                   22-02-03 18:47:51 [    INFO]: Showing README for 4.4/rocketchat=3.18.2
  4942 actions.configure                22-02-03 18:47:51 [   DEBUG]: Calling configure
  4942 actions.configure.progress       22-02-03 18:47:51 [   DEBUG]: 0
  4942 actions.configure                22-02-03 18:47:51 [    INFO]: Configuring 4.4/rocketchat=3.18.2
  4942 actions.configure.progress       22-02-03 18:47:51 [   DEBUG]: 100
  4942 actions.remove                   22-02-03 18:47:51 [   DEBUG]: Calling prescript (prerm)
  4942 actions.remove                   22-02-03 18:47:51 [   DEBUG]: /var/cache/univention-appcenter/appcenter.software-univention.de/4.4/rocketchat_20211101074333.prerm does not exist
  4942 packages                         22-02-03 18:47:51 [   DEBUG]: Holding LOCK
  4942 actions.remove.progress          22-02-03 18:47:51 [   DEBUG]: 5
  4942 actions.configure                22-02-03 18:47:51 [   DEBUG]: Calling /var/cache/univention-appcenter/appcenter.software-univention.de/4.4/rocketchat_20211101074333.configure_host remove --version 3.18.2 --error-file /tmp/tmpp3dvbu9n --locale de
  4942 actions.configure                22-02-03 18:47:56 [   DEBUG]: /var/cache/univention-appcenter/appcenter.software-univention.de/4.4/rocketchat_20211101074333.configure_host returned with 0
  4942 actions.configure.progress       22-02-03 18:47:56 [   DEBUG]: 100
  4942 actions.stop                     22-02-03 18:47:56 [   DEBUG]: Calling stop
  4942 actions.stop.progress            22-02-03 18:47:56 [   DEBUG]: 0
  4942 docker                           22-02-03 18:47:56 [   DEBUG]: Calling in /var/lib/univention-appcenter/apps/rocketchat/compose:
  4942 docker                           22-02-03 18:47:56 [   DEBUG]: Calling docker-compose -p rocketchat stop
  4942 actions.stop.progress            22-02-03 18:47:56 [   DEBUG]: 100
  4942 actions.remove                   22-02-03 18:47:56 [   DEBUG]: Calling in /var/lib/univention-appcenter/apps/rocketchat/compose:
  4942 actions.remove                   22-02-03 18:47:56 [   DEBUG]: Calling docker-compose -p rocketchat stop
  4942 actions.remove                   22-02-03 18:47:57 [   DEBUG]: Calling in /var/lib/univention-appcenter/apps/rocketchat/compose:
  4942 actions.remove                   22-02-03 18:47:57 [   DEBUG]: Calling docker-compose -p rocketchat stop
  4942 actions.remove                   22-02-03 18:47:58 [   DEBUG]: Calling in /var/lib/univention-appcenter/apps/rocketchat/compose:
  4942 actions.remove                   22-02-03 18:47:58 [   DEBUG]: Calling docker-compose -p rocketchat down --remove-orphans
  4942 actions.remove                   22-02-03 18:47:58 [ WARNING]: Removing network rocketchat_appcenter_net
  4942 actions.remove                   22-02-03 18:47:58 [ WARNING]: Network rocketchat_appcenter_net not found.
  4942 actions.remove.progress          22-02-03 18:47:58 [   DEBUG]: 45
  4942 actions.remove                   22-02-03 18:47:58 [    INFO]: Removing localhost from LDAP object
  4942 portalentries                    22-02-03 18:47:58 [   DEBUG]: Changed: {'rocketchat'}
  4942 portalentries                    22-02-03 18:47:58 [   DEBUG]: Local hosts are: ['com01.gehr.lan', '192.168.83.6']
  4942 portalentries                    22-02-03 18:47:58 [   DEBUG]: Processing cn=rocketchat,cn=entry,cn=portals,cn=univention,dc=gehr,dc=lan
  4942 portalentries                    22-02-03 18:47:58 [   DEBUG]: Attrs: {}
  4942 portalentries                    22-02-03 18:47:58 [   DEBUG]: Links: []
  4942 portalentries                    22-02-03 18:47:58 [   DEBUG]: Existing links: [['en_US', 'http://192.168.83.6/rocketchat/'], ['en_US', 'https://com01.gehr.lan/rocketchat/'], ['en_US', 'https://192.168.83.6/rocketchat/'], ['en_US', 'http://com01.gehr.lan/rocketchat/']]
  4942 portalentries                    22-02-03 18:47:58 [   DEBUG]: New links: []
  4942 portalentries                    22-02-03 18:47:58 [   DEBUG]: Removing DN
  4942 actions.remove                   22-02-03 18:47:59 [   DEBUG]: Calling /etc/init.d/apache2 reload
  4942 actions.remove                   22-02-03 18:47:59 [    INFO]: Reloading apache2 configuration (via systemctl): apache2.service.
  4942 actions.remove                   22-02-03 18:47:59 [   DEBUG]: /etc/init.d/apache2 returned with 0
  4942 actions.remove.progress          22-02-03 18:47:59 [   DEBUG]: 55
  4942 attributes                       22-02-03 18:47:59 [   DEBUG]: Adding rocketchatActivated to list of attributes
  4942 attributes                       22-02-03 18:47:59 [   DEBUG]: Removing DN: cn=rocketchatActivated,cn=rocketchat,cn=custom attributes,cn=univention,dc=gehr,dc=lan
  4942 actions.remove.progress          22-02-03 18:47:59 [   DEBUG]: 60
  4942 actions.remove.progress          22-02-03 18:47:59 [   DEBUG]: 70
  4942 actions.remove.progress          22-02-03 18:47:59 [   DEBUG]: 80
  4942 actions.remove                   22-02-03 18:47:59 [    INFO]: Installing join script /var/cache/univention-appcenter/appcenter.software-univention.de/4.4/rocketchat_20211101074333.uinst
  4942 actions.remove                   22-02-03 18:47:59 [   DEBUG]: Calling /usr/sbin/univention-run-join-scripts -dcaccount Administrator -dcpwd /tmp/tmpba4zzwao
  4942 actions.remove                   22-02-03 18:48:01 [    INFO]: Search LDAP binddn:  done
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running pre-joinscripts hook(s):  done
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 03univention-directory-listener.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 04univention-ldap-client.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 08univention-apache.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 11univention-pam.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 18python-univention-directory-manager.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 20univention-directory-policy.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 20univention-join.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 26univention-nagios-common.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 30univention-appcenter.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 30univention-nagios-client.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 33univention-portal.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 35univention-appcenter-docker.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 35univention-management-console-module-appcenter.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 35univention-management-console-module-diagnostic.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 35univention-management-console-module-join.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 35univention-management-console-module-lib.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 35univention-management-console-module-quota.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 35univention-management-console-module-reboot.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 35univention-management-console-module-services.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 35univention-management-console-module-setup.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 35univention-management-console-module-sysinfo.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 35univention-management-console-module-top.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 35univention-management-console-module-ucr.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:02 [    INFO]: Running 35univention-management-console-module-updater.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:03 [    INFO]: Running 36univention-management-console-module-apps.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:03 [    INFO]: Running 50egroupware.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:03 [    INFO]: Running 67univention-mail-server.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:03 [    INFO]: Running 81univention-nfs-server.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:03 [    INFO]: Running 82univention-mail-dovecot.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:03 [    INFO]: Running 92univention-fetchmail-schema.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:03 [    INFO]: Running 92univention-fetchmail.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:03 [    INFO]: Running 92univention-management-console-web-server.inst skipped (already executed)
  4942 actions.remove                   22-02-03 18:48:03 [    INFO]: Running 98univention-pkgdb-tools.inst skipped (already executed)
  6219 cache                            22-02-03 18:48:03 [   DEBUG]: Cache outdated. Need to rebuild
  6219 cache                            22-02-03 18:48:03 [   DEBUG]: Loaded 41 apps from cache
  6219 cache                            22-02-03 18:48:03 [   DEBUG]: Loaded 419 apps from cache
  6219 cache                            22-02-03 18:48:03 [   DEBUG]: Loaded 255 apps from cache
  6219 actions.get                      22-02-03 18:48:03 [   DEBUG]: Calling get
  6219 actions.get.progress             22-02-03 18:48:03 [   DEBUG]: 0
  6219 actions.get                      22-02-03 18:48:03 [    INFO]: Rocket.Chat
  6219 actions.get.progress             22-02-03 18:48:03 [   DEBUG]: 100
  6222 cache                            22-02-03 18:48:04 [   DEBUG]: Cache outdated. Need to rebuild
  6222 cache                            22-02-03 18:48:04 [   DEBUG]: Loaded 41 apps from cache
  6222 cache                            22-02-03 18:48:04 [   DEBUG]: Loaded 419 apps from cache
  6222 cache                            22-02-03 18:48:04 [   DEBUG]: Loaded 255 apps from cache
  6222 actions.get                      22-02-03 18:48:04 [   DEBUG]: Calling get
  6222 actions.get.progress             22-02-03 18:48:04 [   DEBUG]: 0
  6222 actions.get                      22-02-03 18:48:04 [    INFO]: appcenter/apps/rocketchat/container
  6222 actions.get.progress             22-02-03 18:48:04 [   DEBUG]: 100
  6225 cache                            22-02-03 18:48:04 [   DEBUG]: Cache outdated. Need to rebuild
  6225 cache                            22-02-03 18:48:04 [   DEBUG]: Loaded 41 apps from cache
  6225 cache                            22-02-03 18:48:05 [   DEBUG]: Loaded 419 apps from cache
  6225 cache                            22-02-03 18:48:05 [   DEBUG]: Cache outdated. Need to rebuild
  6225 cache                            22-02-03 18:48:05 [   DEBUG]: Loaded 255 apps from cache
  6225 actions.get                      22-02-03 18:48:05 [   DEBUG]: Calling get
  6225 actions.get.progress             22-02-03 18:48:05 [   DEBUG]: 0
  6225 actions.get                      22-02-03 18:48:05 [    INFO]: 3.18.2
  6225 actions.get.progress             22-02-03 18:48:05 [   DEBUG]: 100
  4942 actions.remove                   22-02-03 18:48:06 [    INFO]: Running 51rocketchat-uninstall.uinst done
  4942 actions.remove                   22-02-03 18:48:06 [    INFO]: Running post-joinscripts hook(s):  done
  4942 actions.remove                   22-02-03 18:48:06 [   DEBUG]: /usr/sbin/univention-run-join-scripts returned with 0
  4942 packages                         22-02-03 18:48:06 [   DEBUG]: Releasing LOCK
  4942 actions.remove                   22-02-03 18:48:06 [    INFO]: Potential script hook folder is unused: /var/lib/univention-appcenter/apps/rocketchat/local/hooks/post-remove.d
  4942 actions.upgrade-search           22-02-03 18:48:06 [   DEBUG]: Calling upgrade-search
  4942 actions.upgrade-search.progress  22-02-03 18:48:06 [   DEBUG]: 0
  4942 actions.upgrade-search           22-02-03 18:48:06 [   DEBUG]: Checking 4.4/rocketchat=3.18.2
  4942 actions.upgrade-search.progress  22-02-03 18:48:06 [   DEBUG]: 100
  4942 actions.remove.progress          22-02-03 18:48:06 [   DEBUG]: 100
  4942 utils                            22-02-03 18:48:06 [   DEBUG]: send_information: action=install app=rocketchat value=Creating network "rocketchat_appcenter_net" with the default driver
 status=417
  4942 utils                            22-02-03 18:48:06 [   DEBUG]: tracking information: {'action': 'install', 'status': 417, 'uuid': '57d3bbee-91f8-46ae-a6a5-e15eed967cbc', 'role': 'memberserver', 'app': 'rocketchat', 'version': '3.18.2', 'value': 'Creating network "rocketchat_appcenter_net" with the default driver\nPool overlaps with other one on this address space\n', 'system-uuid': '5ece7845-1055-4047-9038-f305cb58abd0'}
  4942 actions.upgrade-search           22-02-03 18:48:07 [   DEBUG]: Calling upgrade-search
  4942 actions.upgrade-search.progress  22-02-03 18:48:07 [   DEBUG]: 0
  4942 actions.upgrade-search           22-02-03 18:48:07 [   DEBUG]: Checking 4.4/rocketchat=3.18.2
  4942 actions.upgrade-search.progress  22-02-03 18:48:07 [   DEBUG]: 100
  4942 actions.install.progress         22-02-03 18:48:07 [   DEBUG]: 100
  6451 actions.update                   22-02-03 18:51:54 [   DEBUG]: Calling update
  6451 actions.update.progress          22-02-03 18:51:54 [   DEBUG]: 0
  6451 actions.update                   22-02-03 18:51:54 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/app-categories.ini"...
  6451 actions.update                   22-02-03 18:51:54 [   DEBUG]:   ... Not Modified
  6451 actions.update                   22-02-03 18:51:54 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/rating.ini"...
  6451 actions.update                   22-02-03 18:51:54 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/license_types.ini"...
  6451 actions.update                   22-02-03 18:51:54 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/ucs.ini"...
  6451 actions.update                   22-02-03 18:51:54 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/suggestions.json"...
  6451 actions.update                   22-02-03 18:51:54 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/5.0/all.tar.gpg"...
  6451 actions.update                   22-02-03 18:51:54 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.4/all.tar.gpg"...
  6451 actions.update                   22-02-03 18:51:55 [   DEBUG]:   ... Not Modified
  6451 actions.update                   22-02-03 18:51:55 [    INFO]: Downloading "https://appcenter.software-univention.de/meta-inf/4.3/all.tar.gpg"...
  6451 actions.update.progress          22-02-03 18:51:55 [   DEBUG]: 100
  6451 cache                            22-02-03 18:51:55 [   DEBUG]: Cache outdated. Need to rebuild
  6451 cache                            22-02-03 18:51:55 [   DEBUG]: Unable to get mtime for cache: [Errno 2] Datei oder Verzeichnis nicht gefunden: '/var/cache/univention-appcenter/appcenter.software-univention.de/5.0/.apps.de.json'
  6451 cache                            22-02-03 18:51:55 [   DEBUG]: Cannot load cache: mtimes of cache files do not match: None < 1643895064.079741
  6451 cache                            22-02-03 18:51:55 [   DEBUG]: Saved 41 apps into cache
  6451 cache                            22-02-03 18:51:55 [   DEBUG]: Unable to get mtime for cache: [Errno 2] Datei oder Verzeichnis nicht gefunden: '/var/cache/univention-appcenter/appcenter.software-univention.de/4.4/.apps.de.json'
  6451 cache                            22-02-03 18:51:55 [   DEBUG]: Cannot load cache: mtimes of cache files do not match: None < 1643895067.879741
  6451 cache                            22-02-03 18:51:57 [   DEBUG]: Saved 419 apps into cache
  6451 cache                            22-02-03 18:51:57 [   DEBUG]: Cache outdated. Need to rebuild
  6451 cache                            22-02-03 18:51:57 [   DEBUG]: Unable to get mtime for cache: [Errno 2] Datei oder Verzeichnis nicht gefunden: '/var/cache/univention-appcenter/appcenter.software-univention.de/4.3/.apps.de.json'
  6451 cache                            22-02-03 18:51:57 [   DEBUG]: Cannot load cache: mtimes of cache files do not match: None < 1643895069.859741
  6451 cache                            22-02-03 18:51:58 [   DEBUG]: Saved 255 apps into cache
  6451 cache                            22-02-03 18:51:58 [   DEBUG]: Cache outdated. Need to rebuild
  6451 cache                            22-02-03 18:51:58 [   DEBUG]: Unable to get mtime for cache: [Errno 2] Datei oder Verzeichnis nicht gefunden: '/var/cache/univention-appcenter/appcenter.software-univention.de/5.0/.apps.en.json'
  6451 cache                            22-02-03 18:51:58 [   DEBUG]: Cannot load cache: mtimes of cache files do not match: None < 1643895064.079741
  6451 cache                            22-02-03 18:51:58 [   DEBUG]: Saved 41 apps into cache
  6451 cache                            22-02-03 18:51:58 [   DEBUG]: Unable to get mtime for cache: [Errno 2] Datei oder Verzeichnis nicht gefunden: '/var/cache/univention-appcenter/appcenter.software-univention.de/4.4/.apps.en.json'
  6451 cache                            22-02-03 18:51:58 [   DEBUG]: Cannot load cache: mtimes of cache files do not match: None < 1643895067.879741
  6451 cache                            22-02-03 18:52:00 [   DEBUG]: Saved 419 apps into cache
  6451 cache                            22-02-03 18:52:00 [   DEBUG]: Cache outdated. Need to rebuild
  6451 cache                            22-02-03 18:52:00 [   DEBUG]: Unable to get mtime for cache: [Errno 2] Datei oder Verzeichnis nicht gefunden: '/var/cache/univention-appcenter/appcenter.software-univention.de/4.3/.apps.en.json'
  6451 cache                            22-02-03 18:52:00 [   DEBUG]: Cannot load cache: mtimes of cache files do not match: None < 1643895069.859741
  6451 cache                            22-02-03 18:52:01 [   DEBUG]: Saved 255 apps into cache
This is a test environment. I am reinstalling both masters + node.
I am currently in the process of installing the master. No matter which app I install (DHCP, Cups, ADS). They are installed. During the installation, I always get this message. Maybe this is relevant.
grafik
Yes, the logs are different. What is strange are the messages:
What is your last state of Rocketchat? Is it working ? And what says:
docker images
You might also check that your docker network and look if there is any overlapping with your local configurations:
ucr search appcenter/docker/compose/network
I have set up the test environment again with UCS5. Now it worked. Since I installed it exactly the same way according to my documentation, I don’t know where the problem was.
UCS5 still feels a bit bumpy sometimes :slight_smile:
The most important thing, it is working now.
Thanks for sharing.
Have fun :slight_smile:
I had a very similar problem with another app. The problem is, that docker-compose tries to issue the same subnet twice (check in /var/lib/univention-appcenter/apps/[rocketchat-app]/compose/docker-compose.yml and /var/lib/univention-appcenter/apps/[some-other-app]/compose/docker-compose.yml ).
In this case shutdown the containers, run docker network prune and restart your containers.
Im my case this happened after I swtiched back from the test-appcenter to the normal appcenter.
