UCS 4.4.0 ISO booting to GRUB> prompt on Hyper-V
Pretty much as the title says. MD5 matches this
Any ideas?
Screenshot, is the reference to Debian spelt/numbered correctly? (Is it supposed to be that jumbled mess?)
are you using Hyper-V Gen2 VMs?
Currently not working.
See this bug.
/CV
It might be worth adding this information on the download page. I tried both the ISO and the Hyper-V image, both with the same result. Created a gen1 VM and the images boot as expected after thinking this might have something to do with the generation of the VM.
