UCS 4.3 Remotedesktop
Bei mir funktioniert auf den Server 2012 Remotedesktop nicht mehr.
Die Fehlermeldung lautet hier 0xC000005E (kein Anmeldeserver verfügbar)
Kann das jemand bitte mal testen?
Vielen Dank
Peter
Hallo @pixelpeter,
siehe auch: No RDP connection to domain computers - Da ist die Lösung für dein Problem.
Grüße,
- mike
We are currently checking the issue and will report our results.
It looks like the firewall of the UCS 4.3 Samba/AD DCs is blocking TCP ports dynamically allocated by Samba 4.7. In our lab we found that the following adjustment fixed the issue:
ucr set \
     security/packetfilter/package/univention-samba4/tcp/49152:65535/all="ACCEPT" \
     security/packetfilter/package/univention-samba4/tcp/49152:65535/all/en="Dynamic RPC Ports (Samba)"
ucr unset \
     security/packetfilter/package/univention-samba4/tcp/49152/all \
     security/packetfilter/package/univention-samba4/tcp/49152/all/en
service univention-firewall restart
Please note that this needs to be adjusted on all UCS 4.3 Samba/AD DCs.
We will also prepare an errata update to address this.
