I have two problems on a UCS master (4.4-7). I don’t know if they have anything to do with each other.
I can’t say for sure whether the problems came with 4.4.-6 or 4.4-7. Before that, these messages were not present.
The master is connected to a Windows ADS. When I go in the UMC: Domain -> Active Directory Connection the status is: “Active Directory Connection Service is not started.”
When I click on “start” nothing happens.
In the UMC -> System -> Diagnosis I have the error:
SAML certificate verification failed:
File "/usr/lib/python2.7/dist-packages/univention/management/console/modules/diagnostic/__init__.py", line 280, in execute
result = execute(umc_module, **kwargs)
File "/usr/lib/python2.7/dist-packages/univention/management/console/modules/diagnostic/plugins/04_saml_certificate_check.py", line 77, in run
test_identity_provider_certificate()
File "/usr/lib/python2.7/dist-packages/univention/management/console/modules/diagnostic/plugins/04_saml_certificate_check.py", line 90, in test_identity_provider_certificate
for host in socket.gethostbyname_ex(sso_fqdn)[2]:
gaierror: [Errno -2] The name or service is not known
However, I could not reboot because the system is being worked on.
I have also tested the following:
root@tux:~# univention-run-diagnostic-checks -t 02_certificate_check
Domain Admin Login: Administrator
Password:
You can find the logging messages of the diagnostic modules at /var/log/univention/management-console-module-diagnostic.log
ran 02_certificate_check successfully.
The message is still present in the UMC -> Diagnosis. Perhaps it will disappear after a server restart?
