this is the diagnostic:
Administrator@ucs-dc:~$ sudo univention-run-diagnostic-checks
File â/usr/bin/univention-run-diagnostic-checksâ, line 168, in
sys.exit(CLIClient.main())
File â/usr/bin/univention-run-diagnostic-checksâ, line 74, in main
client = Client(None, args.username, args.password)
File â/usr/lib/python3/dist-packages/univention/lib/umc.pyâ, line 412, in init
self.authenticate(self.username, self.password)
File â/usr/lib/python3/dist-packages/univention/lib/umc.pyâ, line 426, in authenticate
return self.umc_auth(username, password)
File â/usr/lib/python3/dist-packages/univention/lib/umc.pyâ, line 548, in umc_auth
return self.request(âPOSTâ, âauthâ, data)
File â/usr/lib/python3/dist-packages/univention/lib/umc.pyâ, line 578, in request
return self.send(request)
File â/usr/lib/python3/dist-packages/univention/lib/umc.pyâ, line 607, in send
raise HTTPError(request, umc_response, self.hostname)
univention.lib.umc.ServiceUnavailable: 503 on ucs-dc.slit.intranet (auth): {âstatusâ: 503, âmessageâ: âThe Univention Management Console Server could not be reached. Please restart univention-management-console-server or try again later.â}
this is the join status (but i dont think, this is the problem, because it appears since 1 year, without any troubles - i deinstalled opsi one year ago)
Warning: âopsi4ucsâ is not configured.
Error: Not all install files configured: 1 missing
this is from the log management-console-join.log (suicide??):
24.06.23 18:55:56.554 MODULE ( PROCESS ) : Module socket initialized.
24.06.23 18:55:56.596 MODULE ( PROCESS ) : Setting user LDAP DN âuid=Administrator,cn=users,dc=slit,dc=intranetâ
24.06.23 18:55:56.596 MODULE ( PROCESS ) : Setting auth type to None
24.06.23 18:55:56.596 MODULE ( PROCESS ) : Initializing module.
24.06.23 19:05:57.697 MAIN ( WARN ) : Shutting down all open connections
24.06.23 20:07:38.386 DEBUG_INIT
24.06.23 20:07:39.602 MODULE ( PROCESS ) : Setting user LDAP DN: âuid=Administrator,cn=users,dc=slit,dc=intranetâ
24.06.23 20:07:39.602 MODULE ( PROCESS ) : Setting auth type: None
24.06.23 20:07:39.602 MODULE ( PROCESS ) : Received request â/univention/command/join/joinedâ: (âAdministratorâ, None, None, âdeâ)
24.06.23 20:07:39.603 MAIN ( WARN ) : Locale âde.UTF-8â is not available: unsupported locale setting
24.06.23 20:07:39.603 MAIN ( WARN ) : Could not set language. Resetting locale.
24.06.23 20:07:39.625 MODULE ( PROCESS ) : Received request â/univention/command/join/scripts/queryâ: (âAdministratorâ, None, None, âdeâ)
24.06.23 20:17:39.626 MODULE ( PROCESS ) : Committing suicide
and this is from management-console-server.log:
24.06.23 18:55:41.267 MODULE ( PROCESS ) : Setting auth type to None
24.06.23 18:55:43.174 MAIN ( PROCESS ) : LDAP bind for user âuid=Administrator,cn=users,dc=slit,dc=intranetâ.
24.06.23 18:55:50.793 MAIN ( PROCESS ) : LDAP bind for user âuid=Administrator,cn=users,dc=slit,dc=intranetâ.
24.06.23 18:55:51.833 MAIN ( PROCESS ) : running: /usr/bin/python3 /usr/sbin/univention-management-console-module -m updater -s /run/univention-management-console/1033-1687625751833.socket -d 2 -l de_DE.UTF-8
24.06.23 18:55:54.569 MAIN ( PROCESS ) : running: /usr/bin/python3 /usr/sbin/univention-management-console-module -m udm -s /run/univention-management-console/1033-1687625754569.socket -d 2 -l de_DE.UTF-8
24.06.23 18:55:54.583 MAIN ( PROCESS ) : running: /usr/bin/python3 /usr/sbin/univention-management-console-module -m join -s /run/univention-management-console/1033-1687625754583.socket -d 2 -l de_DE.UTF-8
24.06.23 18:55:54.703 MAIN ( PROCESS ) : running: /usr/bin/python3 /usr/sbin/univention-management-console-module -m appcenter -s /run/univention-management-console/1033-1687625754703.socket -d 2 -l de_DE.UTF-8
24.06.23 19:05:57.140 MAIN ( WARN ) : Socket died (module=udm)
24.06.23 19:05:57.140 MAIN ( WARN ) : Module process udm died (pid: 31820, exit status: -1, signal: -1, status: -1)
24.06.23 19:05:57.140 MAIN ( WARN ) : Cleaning up requests
24.06.23 19:05:57.140 MAIN ( WARN ) : Remove inactivity timer
24.06.23 19:05:57.140 MAIN ( PROCESS ) : ModuleProcess: stopping 31820
24.06.23 19:05:57.763 MAIN ( WARN ) : Socket died (module=join)
24.06.23 19:05:57.763 MAIN ( WARN ) : Module process join died (pid: 31821, exit status: -1, signal: -1, status: -1)
24.06.23 19:05:57.763 MAIN ( WARN ) : Cleaning up requests
24.06.23 19:05:57.764 MAIN ( PROCESS ) : ModuleProcess: stopping 31821
24.06.23 19:05:57.764 MAIN ( WARN ) : Socket died (module=join)
24.06.23 19:05:57.829 MAIN ( WARN ) : Socket died (module=appcenter)
24.06.23 19:05:57.829 MAIN ( WARN ) : Module process appcenter died (pid: 31823, exit status: -1, signal: -1, status: -1)
24.06.23 19:05:57.829 MAIN ( WARN ) : Cleaning up requests
24.06.23 19:05:57.829 MAIN ( PROCESS ) : ModuleProcess: stopping 31823
24.06.23 19:06:14.571 MAIN ( WARN ) : Socket died (module=updater)
24.06.23 19:06:14.571 MAIN ( WARN ) : Module process updater died (pid: 31791, exit status: -1, signal: -1, status: -1)
24.06.23 19:06:14.571 MAIN ( WARN ) : Cleaning up requests
24.06.23 19:06:14.571 MAIN ( WARN ) : Remove inactivity timer
24.06.23 19:06:14.571 MAIN ( PROCESS ) : ModuleProcess: stopping 31791
24.06.23 19:06:19.652 MAIN ( WARN ) : Shutting down all open connections
24.06.23 19:06:19.654 MAIN ( WARN ) : Shutting down all open connections
24.06.23 19:38:11.383 DEBUG_INIT
24.06.23 19:38:27.750 MAIN ( PROCESS ) : Got SIGUSR1
24.06.23 19:38:36.579 MAIN ( PROCESS ) : Got SIGUSR1
24.06.23 19:38:57.138 MAIN ( PROCESS ) : Got SIGUSR1
24.06.23 19:39:13.191 MAIN ( PROCESS ) : Got SIGUSR1
24.06.23 19:39:38.087 MAIN ( PROCESS ) : Got SIGUSR1
24.06.23 19:40:25.317 MAIN ( PROCESS ) : Got SIGUSR1
24.06.23 19:40:38.579 MAIN ( PROCESS ) : Got SIGUSR1
24.06.23 19:40:49.118 MAIN ( PROCESS ) : Got SIGUSR1
24.06.23 19:41:24.484 MAIN ( PROCESS ) : Got SIGUSR1
24.06.23 19:41:33.601 MAIN ( PROCESS ) : Got SIGUSR1
24.06.23 19:49:37.970 MAIN ( WARN ) : Shutting down all open connections
24.06.23 19:49:39.770 DEBUG_INIT
24.06.23 20:07:34.629 MAIN ( PROCESS ) : LDAP bind for user âuid=Administrator,cn=users,dc=slit,dc=intranetâ.
24.06.23 20:07:38.047 MAIN ( PROCESS ) : running: /usr/bin/python3 /usr/sbin/univention-management-console-module -m join -s /run/univention-management-console/25580-join-1687630058047-3d4c5f48-9476-42cf-8288-7.socket -d 2 -l de_DE.UTF-8
24.06.23 20:07:38.078 MAIN ( PROCESS ) : running: /usr/bin/python3 /usr/sbin/univention-management-console-module -m updater -s /run/univention-management-console/25580-updater-1687630058078-014e3699-52b1-49bd-ae0.socket -d 2 -l de_DE.UTF-8
24.06.23 20:07:38.123 MAIN ( PROCESS ) : running: /usr/bin/python3 /usr/sbin/univention-management-console-module -m udm -s /run/univention-management-console/25580-udm-1687630058122-bbc49a68-21ae-44f2-a9f9-13.socket -d 2 -l de_DE.UTF-8
24.06.23 20:07:38.775 MAIN ( PROCESS ) : running: /usr/bin/python3 /usr/sbin/univention-management-console-module -m appcenter -s /run/univention-management-console/25580-appcenter-1687630058775-e29a4128-4b85-4c4a-a.socket -d 2 -l de_DE.UTF-8
24.06.23 20:17:39.754 MAIN ( PROCESS ) : ModuleProcess: child 26663 (join) exited with 0 (success)
24.06.23 20:17:40.410 MAIN ( PROCESS ) : ModuleProcess: child 26665 (udm) exited with -14 (SIGALRM)
24.06.23 20:17:45.532 MAIN ( PROCESS ) : ModuleProcess: child 26664 (updater) exited with 0 (success)
24.06.23 20:17:45.749 MAIN ( PROCESS ) : ModuleProcess: child 26673 (appcenter) exited with 0 (success)
24.06.23 21:14:24.085 MAIN ( WARN ) : Shutting down all open connections
