(1) separate X session with tightvncserver
- install and start vnc server
-> apt-get update
-> apt-get install tightvncserver
-> tightvncserver :1
You will require a password to access your desktops.
Password:
Warning: password truncated to the length of 8.
Verify:
Would you like to enter a view-only password (y/n)? n
New 'X' desktop is markus:1
Starting applications specified in /home/fbotner/.vnc/xstartup
Log file is /home/fbotner/.vnc/markus:1.log
vncviewer hostname:5901
tightvncserver -kill :1
- The password can be stored in $HOME/.vnc/passwd with the vncpasswd tool and the X session can be configured in the bash script $HOME/.vnc/xstartup
(2) vnc server attached to current screen with x11vnc
- install and start x11vnc (assuming that there is a running X session on display :0)
-> apt-get update
-> apt-get install x11vnc
-> x11vnc -noxdamage -display :0 -auth /var/run/lightdm/root/\:0 --accept popup
-> vncviewer hostname
More information can be found here:
Best regards,
Felix
