Things to check before running UCS on a Canadian VPS
We have been testing UCS on a VPS for small Canadian offices that want their directory and file data kept in Canada for PIPEDA, BC rules and Quebec Law 25. These are the points we check before going live:
  1. Get a static IP and matching reverse DNS before installing, because changing names later is painful.
  2. Plan the domain name carefully and avoid using the public website domain for the internal directory.
  3. Keep the firewall tight and expose only the services remote users really need, ideally behind a VPN.
  4. Take a snapshot before every release update so you can roll back quickly.
  5. Use the Let’s Encrypt app from the App Center for public certificates and confirm renewal works.
  6. Keep backups in Canada too, not only the live server.
  7. Document where user data is stored in case a client asks for a privacy impact assessment.
What else would you add for a UCS server hosted off-site?
I’d add NTP/timezone checks and a restore test. A VPS clock drift can break Kerberos, so confirm the time service is stable and uses reachable sources. Also test a full restore from your Canadian backup onto a fresh VPS, not just that backups run; provider snapshots won’t cover every UCS-specific recovery case. Since it’s off-site, verify the provider doesn’t block ports you need for VPN, directory services or mail submission, and set external monitoring for disk space, LDAP availability and certificate expiry.
