Terminal console does not open
I tried to open the text console directly on the Hyper-V VM but pressing any keys didn’t do anything.
This was also the case directly after a reboot.
Right now I don’t have to do anything on the console but still would like to be able to just in case.
Situation changed as I want to use Pi-Hole and have to set dns-forward (DNS Server - PI - Hole - #3 by 2348798798ihdfishdf).
I’ve managed to login via SSH locally, so problem circumvented but not solved.
