Wollte auf UCS 5.0 updaten.
Scheinbar Reste von KDE auf System vorhanden.
Wie kann man KDE endgültig deinstallieren?
Welche Befehle braucht man?
Bin ziemlicher Laie.
Anbei das Log von der fehlgeschlagenenen Routine.
03.08.22 12:33:29.023 DEBUG_INIT
**** Starting univention-updater with parameter=[’/usr/share/univention-updater/univention-updater’, ‘net’, ‘–updateto’, ‘5.0-2’, ‘–ignoressh’, ‘–ignoreterm’]
Version=4.4
Patchlevel=9
starting net mode
—>DBG:update_available(mode=net, cdrom_mount_point=/media/cdrom, iso=None)
Checking network repository
Update to = 5.0-0
**** Downloading scripts at Wed Aug 3 12:33:32 2022
**** Starting actual update at Wed Aug 3 12:33:38 2022
Starting /tmp/tmpveiFqr/preupM_ccFP.sh (Mi 3. Aug 12:33:38 CEST 2022):
HINT:
Please check the release notes carefully BEFORE updating to UCS 5.0-0:
English version: UCS 5.0 Release Notes
German version: UCS 5.0 Release Notes
3rd party components.
Custom preupdate script /var/lib/local-preup.sh not found
Do you want to continue [Y/n]?
Checking adc_mapping … OK
Checking adc_multiinstance_mapping … OK
Checking architecture … OK
Checking blocking_apps … Unable to cache apps
OK
Checking default_master_packages … OK
Checking disk_space … OK
Checking failed_ldif … OK
Checking for_postgresql94 … OK
Checking hold_packages … OK
Checking kernel … OK
Checking kolab_schema … OK
Checking ldap_connection … OK
Checking ldap_schema … 62ea4f45 /etc/ldap/slapd.conf: line 171: rootdn is always granted unlimited privileges.
OK
Checking legacy_objects … OK
Checking master_version … OK
Checking md5_signature_is_used … OK
Checking min_version … OK
Checking minimum_ucs_version_of_all_systems_in_domain … OK
Checking old_packages … FAIL
Checking overwritten_umc_templates … OK
Checking ox_schema … OK
Checking package_status … OK
Checking python_ucr_template_compatibility … OK
Checking python_ucsschool_hooks_compatibility … OK
Checking role_package_removed … OK
Checking samba_server_schannel … OK
Checking samba_tdb_size … OK
Checking sha1_signature_is_used … OK
Checking slapd_on_member … OK
Checking ssh … OK
Checking system_date_too_old … OK
Checking system_role … OK
Checking term … OK
Checking tls_public_key_size … OK
Checking tls_public_key_size_ucs-sso … OK
Checking ucsschool_computerroom_compatibility … OK
Checking usr_mountpoint … OK
Checking valid_machine_credentials … OK
The system can not be updated to UCS 5.0 due to the following reasons:
old_packages:
WARNING: The following packages from UCS-4 are still installed, which are no longer supported with UCS-5:
univention-kde Mark KDE as manually installed “apt-mark manual kde-standard” to keep KDE
univention-kdm
univention-mozilla-firefox
univention-x-core
Use “univention-remove --purge” with the packages as following arguments to remove them
Error: Update aborted by pre-update script of release 5.0-0
