I use templates to create users e-mail addresses, but sometimes they dont have a firstname and this results in an email-address like “.testuser@domain.tld” what would I need to do in my template to only include the dot “.” in the mail-address if there is a firstname?
Hey,
unfortunately this is not possible via the template mechanism and is mentioned in the handbook too:
For example, the UNIX home directory can be stored under
/home/<title>.<lastname>or the primary email address can be predefined with<firstname>.<lastname>@company.com. Substitutions are generally possibly for any value, but there is no syntax or semantics check. So, if no first name is specified when creating a user, the above e-mail address would begin with a dot and would thus be invalid according to the e-mail standard.
https://docs.software-univention.de/manual/5.0/en/user-management/user-templates.html
You could extend the user creation/modify via hooks or a listener module to generate the mailadress according to your logic tough.
Best regards
Jan-Luca
