I have installed the AD compatible domain controller. My computer could become a member of the domain.
But if I start the DeskApp and activate the logon with the Windows logon data there (use system logon data) I get an error.
“Single Sign On is not supported by the webserver. Please enter your username and password.”
I’ve been searching the web for hours now. I find a lot of basic information about LDAP, but no indication as to whether or how I can activate it in UCS.
The manual is not really meant as a copy & paste howto, so you’d still need to adapt paths (and if you scroll up in the documents it tells you how to generate the keytab.apache file).
Just to understand: Do I have to create the keytab.apache on a Windows machine? I don’t have a Windows server anymore. Otherwise I can only use a Windows10 client.
as I just got a “popular link” notification on the link in my first reply. Meanwhile there is also the possibility to use OpenID Connect for SSO with Kopano WebApp, which does not rely on setting up Kerberos first.
