Hallo Leute,
ich habe “univention-antivir-web” installiert. Gleichzeitiig wurde Dansguardian mit installiert. Danach war eine Internetverbindung über den Proxy mit Firefox nicht mehr möglich.
Ein Versuch squid von Hand zu starten brachte folgende Ergebnisse.
Eine Deinstallation brachte auch kein Erfolg.
Starting Squid HTTP proxy: squid2008/08/27 07:16:06| parseConfigFile: line 14 unrecognized: '@!@'
2008/08/27 07:16:06| parseConfigFile: line 15 unrecognized: 'if 'yes' in [ baseConfig.get('squid/virusscan', ''), baseConfig.get('squid/contentscan', '') ]:'
2008/08/27 07:16:06| parseConfigFile: line 16 unrecognized: ' # dansguardian runs on the default port in this case'
2008/08/27 07:16:06| parseConfigFile: line 17 unrecognized: ' try:'
2008/08/27 07:16:06| parseConfigFile: line 18 unrecognized: ' squidport = int(baseConfig.get('squid/httpport', '3128'))+1'
2008/08/27 07:16:06| parseConfigFile: line 19 unrecognized: ' print "http_port %s" % squidport'
2008/08/27 07:16:06| parseConfigFile: line 20 unrecognized: ' except:'
2008/08/27 07:16:06| parseConfigFile: line 21 unrecognized: ' print "http_port 3129"'
2008/08/27 07:16:06| parseConfigFile: line 22 unrecognized: 'else:'
2008/08/27 07:16:06| parseConfigFile: line 23 unrecognized: ' transparent = '''
2008/08/27 07:16:06| parseConfigFile: line 24 unrecognized: ' if baseConfig.get('squid/transparentproxy').lower() in ['yes', 'true']:'
2008/08/27 07:16:06| parseConfigFile: line 25 unrecognized: ' transparent = 'transparent''
2008/08/27 07:16:06| parseConfigFile: line 26 unrecognized: ' print "http_port %s %s" % ( baseConfig.get('squid/httpport', '3128'), transparent )'
2008/08/27 07:16:06| parseConfigFile: line 27 unrecognized: '@!@'
2008/08/27 07:16:06| parseConfigFile: line 51 unrecognized: '@!@'
2008/08/27 07:16:06| parseConfigFile: line 52 unrecognized: 'for port in baseConfig.get('squid/webports', '80 443 21').split(" "):'
2008/08/27 07:16:06| parseConfigFile: line 53 unrecognized: ' print "acl web_ports port %s" % port'
2008/08/27 07:16:06| parseConfigFile: line 54 unrecognized: '@!@'
2008/08/27 07:16:06| ACL name 'web_ports' not defined!
FATAL: Bungled squid.conf line 55: http_access deny !web_ports
Squid Cache (Version 2.6.STABLE5): Terminated abnormally.
failed!
root@ucssrv:~#
Wie kriege ich die beiden Pakete “univention-antivir-web, Dansguardian” wieder aus dem System so das ich den squid wieder benutzen kann.
Würde mich über ein paar Ideen freuen.
Frank
