I have 2 UCS 4.4-1 Masters installed in different locations in different organizations that have the same behavior on a fresh Wekan install.
No login by users is possible. The user accounts are enabled for Wekan.
wekan-admin can login with password from /etc/wekan-admin.secret
See this extract from univention-app logs wekan (username, domainname and cert replaced):
[INFO] Init LDAP login "user123"
[WARN] Lookup for unset variable: INTERNAL_LOG_LEVEL
[WARN] Lookup for unset variable: LDAP_USER_ATTRIBUTES
[INFO] Init setup
[INFO] Connecting "ldap://ucs.int.xxx.xxx:7389"
[DEBUG] connectionOptions{ url: 'ldap://ucs.int.xxx.xxx:7389',
timeout: 10000,
connectTimeout: 10000,
idleTimeout: 10000,
reconnect: true,
log:
Logger {
domain: null,
_events: {},
_eventsCount: 0,
_maxListeners: undefined,
_level: 30,
streams: [ [Object] ],
serializers: null,
src: false,
fields:
{ name: 'ldapjs',
component: 'client',
hostname: '5f30e840c7a3',
pid: 1 } } }
[INFO] Starting TLS
[DEBUG] tlsOptions {
"rejectUnauthorized": false,
"ca": [
"-----BEGIN CERTIFICATE-----xxx-----END CERTIFICATE-----"
"host": "ucs.int.xxx.xxx"
[ERROR] connection time out 10000
[ERROR] Error: Timeout
What can I check to find out more about what’s causing it?
BR,
Jörn
