Hi, Nexcloud see all users, all groups, but doesn’t match user-group!
Grousp are empty
Updating wrong user-grup parameter.
no gidMember (wrong after update), I’ve modify to uniqueMember
Now works fine
Can you show me, where you modify this parameter? Show full LDAP Filter Group Query
moin,
i got the same issue wiht a fresh UCS and nextcloud. when i try to change the user-group association under the advanced tab to
, it always changes back to
gidNumber
I would really apprecaite if anyone could tell me how to change this!
thx in advance!
okay i found the solution in another post:
by counting the available groups the association parameter gets changed! ![]()
