I have a UCS PDC and BDC on the same subnet.
I an separate subnet I have a UCS slave server. I had to install it on the same subnet first and move it afterwards. Otherwise I could not get the domain join work during installation. After the move I could login to the UCS Web Console. Fine.
Now I wanted to provide a file share from that UCS slave and therefor installed univention-samba4 from the command-line. But the join scripts could not execute. They failed because the nameserver does not resolve the hostname of my master. So I added a second nameserver that does.
# ucr set nameserver2=my-master.local.domain
Still not working. Only if I switch nameserver1 and nameserver2 values in UCR it can resolve.
Is that a bug? Or did I do something wrong?
BR,
Jörn
That’s intended. All members of a domain must be able to resolve and contact the DC master and all DC backups. Each DC backup and DC slave should have at least
nameserver1=<own IP>
nameserver2=<IP of master or backup>
Hello @troeder,
yes, that is clear. I had the following setup.
nameserver1=<IP of internet gateway>
nameserver2=<IP of master>
It looked like the join script gave up after the first nameserver.
When I switched the order it worked.
nameserver1=<IP of master>
nameserver2=<IP of internet gateway>
Not true: DC slaves need only one DC master or DC backup.
dns/forwarder1 dns/forwarder2 and dns/forwarder3 are for resolving external domains.
nameserver1-3 is for the domains own nameservers only.
It should be:
dns/forwarder1=<IP of internet gateway>
nameserver2+3 dns/forwarder2+3 should be unset, if not required.
