Hello All,
we using here UCS 4.4 with Kopano 3.5.5.2276. We use shared contacts. I can see all the contacts, edit… but if i write a new Mail i can’t choose that contacts. How i can set an shared adressbook as default?
Thanks
Hello All,
Thanks
Hi @boospy,
as I have already told you I would rather recommend to ask questions that are not directly related to UCS or the Kopano integration into it on the Kopano Forum.
In this specific case your questions could also have been answered with a search on this forum (or a look into the WebApp documentation, or a search on the Kopano forum)
Sorry, my fault. Will do this next post for kopano.
Very Thanks
It has worked perfectly. Nice evening!
