[solved]Guacamole "Anmeldungsfehler"
I installed guacamole on our UCS and created an LDAP guacamole configuration by adding the Administrator user as member. Unfortunately when trying to log in I get the message “Anmeldungsfehler”.
The only error message I found in the log is the following
[http-nio-8080-exec-9] WARN o.a.g.r.auth.AuthenticationService - Authentication attempt from [210.13.236.134, 172.16.0.1] for user "Administrator" failed.
The LDAP module seems to be loaded.
[localhost-startStop-1] INFO o.a.g.extension.ExtensionModule - Extension "LDAP Authentication" loaded.
Any ideas how to access guacamole?
thx, Andy
Okay . . . due to some reason it took a while the button to activate usage of the app was visible in the user settings. Now it’s there and everything works.
