Hello Professionals,
I have some problems to send mails. Please see the followed mail.info log. I hope that can somebody identify the problem and give me a detail solution for this problem because I’m a novice. Thx in advanced!:
Aug 24 15:07:34 mail fetchmail[1906]: 1 Nachricht für info@meineMail.de bei Pop3.strato.de (1741 Bytes).
Aug 24 15:07:34 mail postfix/smtpd[23208]: connect from localhost[127.0.0.1]
Aug 24 15:07:34 mail postfix/smtpd[23208]: warning: Illegal address syntax from localhost[127.0.0.1] in MAIL command: <info@-swmacontact.de>
Aug 24 15:07:34 mail fetchmail[1906]: Nachricht info@meineMail.de@Pop3.strato.de:1 von 1 wird gelesen (1741 Bytes) (Log-Meldung unvollständig)
Aug 24 15:07:34 mail fetchmail[1906]: SMTP-Fehler: 501 5.1.7 Bad sender address syntax
Aug 24 15:07:34 mail postfix/smtpd[23211]: connect from localhost[127.0.0.1]
Aug 24 15:07:34 mail postfix/smtpd[23211]: warning: Illegal address syntax from localhost[127.0.0.1] in RCPT command: <info@-swmacontact.de>
Aug 24 15:07:34 mail postfix/smtpd[23211]: disconnect from localhost[127.0.0.1] helo=1 mail=1 rcpt=0/1 quit=1 commands=3/4
Aug 24 15:07:34 mail fetchmail[1906]: nicht gelöscht
Aug 24 15:07:34 mail postfix/smtpd[23208]: disconnect from localhost[127.0.0.1] ehlo=1 mail=0/1 rset=1 quit=1 commands=3/4
I did try to fix one problem by deleting the wrong mail adress but not succesfull:
root@mail:~# postqueue -p
Mail queue is empty
root@mail:~# postsuper -d info@-swmacontact.de
postsuper: warning: invalid mail queue id: info@-swmacontact.de
But then I see the additional problem why I cant send mails with fetchmail SMTP error 501.
