Uzzi
                    October 11, 2023,  6:15pm
                  1
              Hi, I’ve followed Problem: 96univention-samba4 fails with ctx.local_samdb.transaction_commit  but I’ve alwayse error:
ERROR: incorrect instanceType part of Binary DN binary component for msDS-HasInstantiatedNCs in object CN=NTDS Settings,CN=UCS-master,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=domain
and
re-indexed database : (68, 'reindexing failed
these are join errors:
An operation failed during a batch mode transaction, the transaction was rolled back
              Hi Uzzi,
what is the complete re-index failed output. I think you have to fix the re-index failure.
                Uzzi
                    October 12, 2023, 12:09pm
                  3
              Hi @scheinig  , thank you for feedback.
Processing section "[global]"
Checking 5745 objects
ERROR: incorrect instanceType part of Binary DN binary component for msDS-HasInstantiatedNCs in object CN=NTDS Settings,CN=UCS-master,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=xxxxxx,DC=intranet - B:8:00000005:<GUID=626a920e-3831-4756-a079-8cca160550cd>;<RMD_ADDTIME=132125937350000000>;<RMD_CHANGETIME=132125984120000000>;<RMD_FLAGS=1>;<RMD_INVOCID=c8a4341e-8676-4226-9e89-74b792a812be>;<RMD_LOCAL_USN=360382>;<RMD_ORIGINATING_USN=360382>;<RMD_VERSION=2>;CN=Configuration,DC=xxxxx,DC=intranet
Change DN to B:8:0000000D:<GUID=626a920e-3831-4756-a079-8cca160550cd>;<RMD_ADDTIME=132125937350000000>;<RMD_CHANGETIME=132125984120000000>;<RMD_FLAGS=1>;<RMD_INVOCID=c8a4341e-8676-4226-9e89-74b792a812be>;<RMD_LOCAL_USN=360382>;<RMD_ORIGINATING_USN=360382>;<RMD_VERSION=2>;CN=Configuration,DC=xxxxxx,DC=intranet? [YES]
Failed to fix incorrect instanceType part of Binary DN on attribute msDS-HasInstantiatedNCs : (16, 'Attribute msDS-HasInstantiatedNCs already deleted for target GUID 626a920e-3831-4756-a079-8cca160550cd')
Checked 5745 objects (1 errors)
descriptor_prepare_commit: changes: num_registrations=0
descriptor_prepare_commit: changes: num_registered=0
descriptor_prepare_commit: changes: num_toplevel=0
descriptor_prepare_commit: changes: num_processed=0
descriptor_prepare_commit: objects: num_processed=0
descriptor_prepare_commit: objects: num_skipped=0
And this is samba-tool dbcheck --reindex output:
Re-indexing...
re-indexed database : (68, 'reindexing failed: Entry DC=\\ mattermost,DC=xxxxx.intranet,CN=MicrosoftDNS,DC=DomainDnsZones,DC=xxxxx,DC=intranet already exists')
              Hi Uzzi,
it seems there is an other object, maybe an deleted one in samba.
univention-s4search --cross-ncs --show-deleted -b DC=xxxxx.intranet,CN=MicrosoftDNS,DC=DomainDnsZones,DC=xxxxx,DC=intranet 1.1 | grep mattermost
Best Christina
                Uzzi
                    October 14, 2023,  7:35am
                  5
              thi is output:
GENSEC backend 'gssapi_spnego' registered
GENSEC backend 'gssapi_krb5' registered
GENSEC backend 'gssapi_krb5_sasl' registered
GENSEC backend 'spnego' registered
GENSEC backend 'schannel' registered
GENSEC backend 'ncalrpc_as_system' registered
GENSEC backend 'sasl-EXTERNAL' registered
GENSEC backend 'ntlmssp' registered
GENSEC backend 'ntlmssp_resume_ccache' registered
GENSEC backend 'http_basic' registered
GENSEC backend 'http_ntlm' registered
GENSEC backend 'http_negotiate' registered
GENSEC backend 'krb5' registered
GENSEC backend 'fake_gssapi_krb5' registered
dn: DC=\ mattermost,DC=xxxx.intranet,CN=MicrosoftDNS,DC=DomainDnsZones,DC=xxxx,DC=intranet
dn: DC=\ mattermost,DC=xxxxxx.intranet,CN=MicrosoftDNS,DC=DomainDnsZones,DC=xxxx,DC=intranet
              HI Uzzi,
so you this looks like two entries in two different zones? This is not the samba object, right? So I guess this is the issue here.
I would like to compare 7check the GUID from the objects:
univention-s4search --cross-ncs DC=*mattermost objectGUID
and I would like to check the hostrecords via udm
udm dns/host_record list --filter  relativeDomainName=*mattermost
                Uzzi
                    October 16, 2023, 12:57pm
                  7
              univention-s4search --cross-ncs DC=*mattermost objectGUID;
# record 1
dn: DC=\ mattermost,DC=xxx.intranet,CN=MicrosoftDNS,DC=DomainDnsZones,DC=xxx,DC=intranet
objectGUID: e8b22b70-c0b6-42e3-903e-878ba70710c4
# record 2
dn: DC=\ mattermost,DC=xx.intranet,CN=MicrosoftDNS,DC=DomainDnsZones,DC=xx,DC=intranet
objectGUID: 696b66d1-ff7a-46c8-8a78-46085ea8cb36
udm dns/host_record list --filter  relativeDomainName=*mattermos:
DN: relativeDomainName=\20mattermost,zoneName=xxxx.intranet,cn=dns,dc=xxxx,dc=intranet
  a: 172.16.6.34
  zonettl: 3 hours
                Uzzi
                    October 17, 2023,  2:10pm
                  9
dn: DC=\ mattermost,DC=xxxx.intranet,CN=MicrosoftDNS,DC=DomainDnsZones,DC=xxx,DC=intranet
              So these objects are the same?
or are they different. The “xxx” vs “xxxx” is confiusing.
                Uzzi
                    October 17, 2023,  2:40pm
                  11
              no hahahaha I’ve only write XXXX to obfuscate real domain name
              okay,  so it is two times in the samba database.
univention-s4search --cross-ncs ObjectGUID=e8b22b70-c0b6-42e3-903e-878ba70710c4 > mattermost1.s4-ldif
univention-s4search --cross-ncs ObjectGUID=696b66d1-ff7a-46c8-8a78-46085ea8cb36 > mattermost2.s4-ldif
And you can delete the entry like that:
ldbdel -H /var/lib/samba/private/sam.ldb --cross-ncs 'DC=\ mattermost,DC=xx.intranet,CN=MicrosoftDNS,DC=DomainDnsZones,DC=xx,DC=intranet'
                Uzzi
                    October 20, 2023,  4:11pm
                  13
 scheinig:
completed re-index OK
Now I’ve joined a new slave node
Thank you
              awesome! I am happy, your problem is solved.
