Site-to-site connection
Hi! Pls help me or explain, why my vpn connection doesn’t work. I read manual from https://www.bytemine.net/files/openvpn4ucs_howto_en.pdf
I have set option for vpn connection, which working well for users. Next step site-to-site connect between master - slave. On master I set Site-to-Site VPN area in UMC. Result of is appeared file
/etc/openvpn/sitetosite.conf, on master with text:
### Constant values
proto udp
push "route 192.168.0.0 255.255.252.0"
push "dhcp-option DNS 192.168.0.11"
push "dhcp-option DOMAIN corp.softwarelab.net"
keepalive 10 120
comp-lzo
persist-key
persist-tun
verb 9
mute 5
status /var/log/openvpn/openvpn-sitetosite-status.log
management /var/run/management-udp-sitetosite unix
dev tun
secret /etc/openvpn/sitetosite.key
cipher AES-256-CBC
### Values which can be changed through UDM
port 1195
remote ip-ucs-slave-server
ifconfig 10.153.176.1 10.153.176.2
On the slave side I created openvpn config file:
## Topology and protocol settings
dev tun
proto udp
management /var/run/management-udp unix
## the shared secret for the connection
## Encryption Cypher to use for the VPN
cipher AES-256-CBC
## Compression algorithm to use
comp-lzo
## The external DNS name or IP of the other VPN
remote ip-ucs-master 1195
## The address used internally by OpenVPN
ifconfig 10.153.176.2 10.153.176.1
## Route traffic to remote network
## The network should be the one, used by the remote server
route 192.168.0.0 255.255.255.0
## Additional server configuration
keepalive 10 120
persist-key
persist-tun
## Configure the logfile and the verbosity
verb 9
mute 5
status /var/log/openvpn-status.log
I can’t ping 10.153.176.1 from slave and 10.153.176.2 from master. Maybe my configs is wrong?
I resolved my problem. Maybe someone it will be interesting. I added float option to config file for master ucs.
### Constant values
float
proto udp
In my logs was messages look as
... (allow this incoming source address/port by removing --remote or adding --float)
