I’m a novice. I’m warning you
I’ve Nexcloud and OpenProject installed on local server and I look for a simple local backup solution of these instances/containers (db/files, otherwise just db).
I would like store this backup on an simple external storage (and probably online in the future).
I’ve tried apps available on the market (Bacula, Bareos), but it seems me these are neither easy-to-use solutions nor intended for a local backup.
Otherwise I’ll probably go to a CentOS installation with Docker, I’m pretty sure to find a backup solution that suits me…
Thanks
Regards
