Setting up OpenID for Cloudflare access and Team
Cloudflare has launched a new Cloudflare Access system that seems like a powerful replacement for secure VPN connection.
Is it possible to setup Cloudflare Access using SAML or OpenID connect App from UCS?
It will be great if someone can highlight how this can be achieved. Thanks,
Hello @abhinavjain,
UCS supports SAML and OpenID Connect (with the OpenID Connect provider app installed). You can try both options and check what works best for you.
Best regards,
Nico
Thanks, Gulden. For now, I have setupthe one-time pin option as our startup team is small and it is working fine.
