Setdefaultsignature.py ImportError: No module named MAPI.Util
Following the suggestion in:
I tried the example_wrapper.sh
But I get the error:
File “setdefaultsignature.py”, line 2, in
from MAPI.Util import *
I use UCS 4.4-8 errata 995
Kopano Core: 8.7.1.0-1
Kopano WebApp 3.5.14.2539-2
No idea anyone?
I’d really need help here.
Hi @Hans,
that sounds like you are running it with the wrong version of Python or like the python-mapi package is not installed for the version of Python you are running.
If you use the setup in a production environment it is always recommended to also purchase a Kopano subscription. This give you on one hand access to updated packages (the above error being a bug in said version is not out of the question) and also gives you direct access to the Kopano support.
The python version was the hint I needed. I just used:
python3 setdefaultsignature.py username
to set the default signature.
It seems to work for outside emails but the inline image in the signature gets stripped for emails within the family. Very strange …
