Samba4 configure fails in join script after upgrade to Univention 5.0
I may be getting closer! Unable to login to web interface with Administrator password, or use Administrator account - this Univention server was originally built as an Active-Directory connected Domain Controller (not AD takeover), and is now in “Primary Directory Mode” after in place upgrade to UCS 5.0
root@ucs-bdc:~# univention-check-join-status
Warning: ‘nextcloud’ is not configured.
Warning: ‘univention-samba4’ is not configured.
Warning: ‘univention-samba4-dns’ is not configured.
Warning: ‘univention-samba4-saml-kerberos’ is not configured.
Error: Not all install files configured: 4 missing
and:
root@ucs-bdc:~# univention-run-join-scripts
Running 50nextcloud.inst failed (exitcode: 1)
Running 50wekan.inst skipped (already exec uted)
Running 50wordpress.inst skipped (already exec uted)
Running 81univention-ad-connector.inst skipped (already exec uted)
Running 81univention-nfs-server.inst skipped (already exec uted)
Running 90univention-bind-post.inst skipped (already exec uted)
Running 91univention-saml.inst skipped (already exec uted)
Running 92univention-management-console-web-server.inst skipped (already exec uted)
Running 96univention-samba4.inst failed (exitcode: 1)
Running 98univention-pkgdb-tools.inst skipped (already exec uted)
Running 98univention-samba4-dns.inst failed (exitcode: 1)
Running 98univention-samba4-saml-kerberos.inst failed (exitcode: 1)
Running post-joinscripts hook(s): done
Any help appreciated! I had issues with samba4 and schannel so uninstalled it and reinstalled but something went amiss…
root@ucs-bdc:~# univention-adconnector-list-rejected
kdestroy: krb5_cc_destroy: Did not find a plugin for ccache_ops
File “/usr/sbin/univention-adconnector-list-rejected”, line 118, in
main()
File “/usr/sbin/univention-adconnector-list-rejected”, line 80, in main
ad.init_ldap_connections()
File “/usr/lib/python3/dist-packages/univention/connector/ad/init.py”, line 535, in init_ldap_connections
self.open_ad()
File “/usr/lib/python3/dist-packages/univention/connector/ad/init.py”, line 692, in open_ad
self.get_kerberos_ticket()
File “/usr/lib/python3/dist-packages/univention/connector/ad/init.py”, line 669, in get_kerberos_ticket
raise kerberosAuthenticationFailed(‘The following command failed: “%s” (%s): %s’ % (’ '.join(cmd_block), p1.returncode, stdout.decode(‘UTF-8’, ‘replace’)))
univention.connector.ad.kerberosAuthenticationFailed: The following command failed: “kinit --no-addresses --password-file=/tmp/tmpbmx46pu5 ucs-bdc$” (1): kinit: krb5_get_init_creds: unable to reach any KDC in realm REALDOMAIN.COM
and:
root@ucs-bdc:~# univention-ldapsearch uid= sambaSID
extended LDIF
LDAPv3
base <dc=realdomain,dc=com> (default) with scope subtree
filter: uid=
requesting: sambaSID
search result
search: 3
result: 0 Success
numResponses: 1
root@ucs-bdc:~# univention-s4search sAMAccountName= objectSid
lpcfg_do_global_parameter: WARNING: The “server schannel” option is deprecated
Failed to inquire of target’s available sasl mechs in rootdse search: NT_STATUS_IO_TIMEOUT
Failed to bind - LDAP client internal error: NT_STATUS_IO_TIMEOUT
Failed to connect to ‘ldaps://ucs-bdc.realdomain.com’ with backend ‘ldaps’: LDAP client internal error: NT_STATUS_IO_TIMEOUT
Failed to connect to ldaps://ucs-bdc.realdomain.com - LDAP client internal error: NT_STATUS_IO_TIMEOUT
root@ucs-bdc:~# univention-s4connector-list-rejected
-bash: univention-s4connector-list-rejected: command not found
root@ucs-bdc:~# net getdomainsid
pdb backend samba_dsdb did not correctly init (error was NT_STATUS_UNSUCCESSFUL)
WARNING: Could not open passdb
root@ucs-bdc:~#
root@ucs-bdc:~# univention-s4search --cross-ncs cn=‘Domain Admins’ objectSid
Any help would be great. Univention 5 did not join domain it was upgraded from correctly but ir ran great for years before the update to 5. Now it does not work
root@ucs-bdc:~# samba-tool drs showrepl
Failed to connect host 192.168.2.79 on port 135 - NT_STATUS_CONNECTION_REFUSED
Failed to connect host 192.168.2.79 (ucs-bdc.realdomain.com) on port 135 - NT_STATUS_CONNECTION_REFUSED.
ERROR(<class ‘samba.drs_utils.drsException’>): DRS connection to ucs-bdc.realdomain.com failed - drsException: DRS connection to ucs-bdc.realdomain.com failed: (3221226038, ‘The transport-connection attempt was refused by the remote system.’)
File “/usr/lib/python3/dist-packages/samba/netcmd/drs.py”, line 55, in drsuapi_connect
(ctx.drsuapi, ctx.drsuapi_handle, ctx.bind_supported_extensions) = drs_utils.drsuapi_connect(ctx.server, ctx.lp, ctx.creds)
File “/usr/lib/python3/dist-packages/samba/drs_utils.py”, line 63, in drsuapi_connect
raise drsException(“DRS connection to %s failed: %s” % (server, e))
root@ucs-bdc:~# samba-tool dbcheck --cross-ncs --check-for-conflicts
ERROR(<class ‘ValueError’>): uncaught exception - unable to parse dn string
File “/usr/lib/python3/dist-packages/samba/netcmd/init.py”, line 186, in _run
return self.run(*args, **kwargs)
File “/usr/lib/python3/dist-packages/samba/netcmd/dbcheck.py”, line 151, in run
check_for_conflicts=check_for_conflicts)
File “/usr/lib/python3/dist-packages/samba/dbchecker.py”, line 117, in init
self.infrastructure_dn = ldb.Dn(samdb, “CN=Infrastructure,” + samdb.domain_dn())
root@ucs-bdc:~# samba-tool drs kcc
root@ucs-bdc:~#
root@ucs-bdc:~# samba-tool ntacl sysvolcheck
ERROR(runtime): uncaught exception - samdb_domain_sid failed
File “/usr/lib/python3/dist-packages/samba/netcmd/ntacl.py”, line 444, in run
domain_sid = security.dom_sid(samdb.domain_sid)
File “/usr/lib/python3/dist-packages/samba/samdb.py”, line 921, in get_domain_sid
return dsdb._samdb_get_domain_sid(self)
root@ucs-bdc:~# /usr/share/univention-samba4/scripts/check_essential_samba4_dns_records.sh
Host gc._msdcs.realdomain.com not found: 3(NXDOMAIN)
Host _gc._tcp.realdomain.com not found: 3(NXDOMAIN)
Host _ldap._tcp.gc._msdcs.realdomain.com not found: 3(NXDOMAIN)
_ldap._tcp.realdomain.com has SRV record 0 100 7389 ucs-bdc.realdomain.com.
Host _ldap._tcp.dc._msdcs.realdomain.com not found: 3(NXDOMAIN)
Host _ldap._tcp.pdc._msdcs.realdomain.com not found: 3(NXDOMAIN)
host: ‘_ldap._tcp…domains._msdcs.realdomain.com’ is not a legal name (empty label)
Host _kerberos._tcp.dc._msdcs.realdomain.com not found: 3(NXDOMAIN)
_kerberos._tcp.realdomain.com has SRV record 0 100 88 ucs-bdc.realdomain.com.
_kerberos._udp.realdomain.com has SRV record 0 100 88 ucs-bdc.realdomain.com.
Host _kpasswd._tcp.realdomain.com not found: 3(NXDOMAIN)
Host _kpasswd._udp.realdomain.com not found: 3(NXDOMAIN)
_kerberos.belldesign.com descriptive text “realdomain”
root@ucs-bdc:~# ucr search dns/backend
dns/backend: ldap
Bind can use different backends for its configuration: ‘ldap’ configures the use of the UCS OpenLDAP directory. ‘samba4’ uses the Samba 4 LDB database. When using the Samba backend, a search is performed in the LDAP for every DNS request. Wi th the OpenLDAP backend, a search is only performed in the directory service if the DNS data has changed. On Directory No des running ‘samba4’, the backend must not be changed to ‘ldap’.
In the end I autoremoved it and can login with ldap only
