SAMBA stopped syncing with LDAP NT_STATUS_CONNECTION_REFUSED
Our server stopped syncing OPENLDAP with SAMBA4 for no apparent reason.
The error is:
Failed to connect to ldap URL ‘ldaps://ucs1.domain.lan’ - LDAP client internal error: NT_STATUS_CONNECTION_REFUSED
Failed to connect to ‘ldaps://ucs1.domain.lan’ with backend ‘ldaps’: LDAP client internal error: NT_STATUS_CONNECTION_REFUSED
Failed to connect to ldaps://ucs1.domain.lan - LDAP client internal error: NT_STATUS_CONNECTION_REFUSED
They both are working OK (SAMBA works and LDAP works) but don’t sync info between them.
For example, a created group on UCS (LDAP) won’t appear on SAMBA and vice-versa.
Any pointers on how to fix this?
Thanks!
Same problem here, did you find any solution?
