Samba Problem Warning Message
samba-tool ntacl sysvolcheck returned a problem with the sysvol ACLs.
then my folders… and at the last lines I got:
connect_acl_xattr: setting 'inherit acls = true' 'dos filemode = true' and 'force unknown acl user = true' for service sysvol
Initialising default vfs hooks
Initialising custom vfs hooks from [/[Default VFS]/]
Initialising custom vfs hooks from [acl_xattr]
Initialising custom vfs hooks from [dfs_samba4]
Can anyone help me please ?
Hey,
these aren’t real warnings. They’re debug message that are output due to the UCR variable samba/debug/level being set to a value grater than 1.
Kind regards.
mosu
@Moritz_Bunkus ,
What i do wrong because an USER with an GROUP can’t read/write/access a folder with permissions.
The permissions are ok but when i try to create or delete an archive I can’t!
