iget the following error : (the change within the directory database was a rename from small letters to capital letters - maybe this is a bug in the sync script - which cannot handle this situation??)
21.11.2017 10:15:55,403 LDAP (PROCESS): sync to ucs: Resync rejected dn: OU=workstations,OU=SCZ_COMPUTER,OU=SCZ-OU,DC=scz,DC=intranet
21.11.2017 10:15:55,405 LDAP (PROCESS): sync to ucs: [ ou] [ add] ou=workstations,ou=scz_computer,ou=scz-ou,dc=scz,dc=intranet
21.11.2017 10:15:55,418 LDAP (ERROR ): Unknown Exception during sync_to_ucs
21.11.2017 10:15:55,418 LDAP (ERROR ): Traceback (most recent call last):
File “/usr/lib/pymodules/python2.7/univention/s4connector/init.py”, line 1570, in sync_to_ucs
result = self.add_in_ucs(property_type, object, module, position)
File “/usr/lib/pymodules/python2.7/univention/s4connector/init.py”, line 1344, in add_in_ucs
res = ucs_object.create(serverctrls=serverctrls, response=response)
File “/usr/lib/pymodules/python2.7/univention/admin/handlers/init.py”, line 381, in create
dn = self._create(response=response, serverctrls=serverctrls)
File “/usr/lib/pymodules/python2.7/univention/admin/handlers/init.py”, line 1036, in _create
self.lo.add(self.dn, al, serverctrls=serverctrls, response=response)
File “/usr/lib/pymodules/python2.7/univention/admin/uldap.py”, line 474, in add
raise univention.admin.uexceptions.objectExists(dn)
objectExists: ou=workstations,ou=scz_computer,ou=scz-ou,dc=scz,dc=intranet
