Root-ca.crt not found inside OX-Connector container
Hi!
After installing OX-Connector 7.10.6 on UCS 5.0.8 and reading the OX-Connector docs, I see that executing this is giving me an error:
root@radon:/opt/open-xchange/sbin# univention-app shell ox-connector
/oxp # wget --no-check-certificate https://myserver.mydc.mydomain.com.ar.local/root-ca.crt -O /usr/local/share/ca-certificates/ox-app-suite.crt
Connecting to myserver.mydc.mydomain.com.ar.local (10.1.1.29:443)
wget: server returned error: HTTP/1.1 404 Not Found
The only certificate I see on the OX-Connector container is the ucs.crt on the same location.
Because of this I cannot execute the next command on the OX-Connector manual, “update-ca-certificates”.
This is a server that was upgraded version by version starting from 4.4 until this last one, 5.0.8, with App Suite also upgraded version by version until 7.10.6. There is a Windows Domain Controller where we declare the users, and the UCS syncs the users to allow them to have mail, calendar, tasks, contacts, etc.
The server name is myserver.mydomain.com.ar when contacted from the outside, and myserver.mydc.mydomain.com.ar.local when from the inside.
Any clue will be very appreciated.
Thanks, and best regards,
HeCSa.
