installation & ldap configuration of BigBlueButton is straight forward and works like a charm. Could someone advise how UCS@school stores the role information (student, teacher, staff) and how to mapp this to accordingly created BBB Greenlight Roles?
The UCS@school-Options UCS@school-Administrator and UCS@school-Lehrer are currently mapped to LDAP object classes (e.g. ucsschoolTeacher, ucsschoolStudent, ucsschoolAdministrator). But we are in the middle of a migration to a new, more flexible mechanism which uses the LDAP attribute ucsschoolRole. Hint: if the migration is completed, it is likely that the objectclasses will be removed. So the LDAP attribute ucsschoolRole should be used for new implementations.
The objectclass and ucsschoolRole are currently kept in sync by the UMC modules Benutzer (Schulen) and the UCS@school importer. If the UMC module Benutzer is used directly, there might be inconsistencies, that should be checked and fixed to avoid problems.
So if ucsschoolRole does not match the LDAP object classes, please investigate the reason for this inconsistency.
Regarding Greenlight/BigBlueButton:
the last time I tested BigBlueButton, Greenlight only added the LDAP attribute specified in LDAP_ROLE_FIELD to the existing Greenlight user
This means that if in the Greenlight configuration LDAP_ROLE_FIELD is set to e.g. univentionFreeAttribute2 and on the LDAP user foo the attribute univentionFreeAttribute2 is set to admin, then the role admin is added to the Greenlight user (univentionFreeAttribute2 is only an example, it may be any other LDAP attribute that just contains the name of the Greenlight role).
It should be noted, however, that only new roles have been added in Greenlight. This means that if foo is downgraded from adminto user, the role admin at the corresponding Greenlight user is not removed again.
So far I don’t know of any workaround or fix for this.
BTW: this combination of user roles is not allowed in UCS@school:
A user can only be one of student, staff, teacher, teacher and staff, teacher and admin or staff and admin.
Please use only the UCS@school UMC modules to create school users. They will take care you have consistent users and they are in all required groups.
