Rocketchat android – SSL handshake failure
The android App does not connect to RocketChat@UCS.
rocketchat is installed on UCS 4.4. which is connected to the internet via a HA-Proxy.
it does work for WEB & desktop-app*) access but not for android.
The HA-Proxy uses an UCS-Cert, which is issued for its DNS-name. (works also with nextcloud & Portal).
The CA-Root is imported on the phone.
The android App does not connect, throwing an error-msg, that the URL would not be correct. (In german: Hoppla!, Die eingegeben URL ist ungültig…) - not telling the real pbl.
in the HA-Proxy logs:
Aug 25 06:52:45 hostname haproxy[196]: 103.1.30.36:2357 [25/Aug/2020:06:52:45.132] https-in/1: SSL handshake failure
Aug 25 06:52:46 hostname haproxy[196]: 103.1.30.36:2358 [25/Aug/2020:06:52:45.754] https-in/1: SSL handshake failure
Aug 25 06:52:46 hostname haproxy[196]: 103.1.30.36:2359 [25/Aug/2020:06:52:46.325] https-in/1: SSL handshake failure
As far as i know, latest since android app-version 4.7 self-signed Certs should work?
Versions:
Server: UCS 4.4
Rocket.Chat Version: 3.0.2
NodeJS Version: 12.14.0 - x64
MongoDB Version: 4.0.3
Mobile:
rocketChat: 4.10.0.2135
any hints on that?
on a site note:
*) the desktop app did only find the server with a trailing / at the end of the URL:
https://host.domain.com/rocketchat/
without it, there had been 404 errors form the UCS apache-proxy …
TIA
guenter
bump
what are your experiences wit this kind of setup?
Hello @chymian,
I’m not sure, if it relates to your topic. I just setup a test instance with Rocket.Chat 3.5.3 that has been released to the App Center this week, and I came across the notification:
Notice
Be sure to register your server before July 31, 2020 to keep your mobile notifications flowing.
It links to this posting: Enforcing Registration Requirement to Utilize Push Gateway - Announcements - Rocket.Chat
Maybe it helps.
Best regards,
Nico
@gulden
thanks nico that you take the time to answer
but that is about to register a server with rocket.chat to be able to receive push messages in future.
the pbl. my customer is facing, is that the mobile-app does not work with a UCS-certificate.
greetings
guenter
hi @chymian
Does it work on that same android phone with nextcloud Android?
What is the actual DNS-name used ?
